โFeb-14-2015 10:05 PM
โFeb-21-2015 11:46 AM
โFeb-21-2015 06:40 AM
โFeb-21-2015 05:19 AM
oldbeek wrote:
I contacted "EDPM Coatings" on the net. 2 part EDPM coating will bond with the original edpm roof. When coated there are no more black streaks. A lot of prep is required. Removed all old caulk and scuffed all other products with 100 grit sand paper. Applied it to all vents and covers to stop future UV damage. Applied it over the moldings on the sides and caps. Applied past those moldings by 1/2 inch onto the caps and sides. Remember that 1/2 inch was scuffed with 100 grit sand paper. There were old damaged areas that were repaired with Eternabod tape. EDPM bonds to that also. No more seams no caulk, a total EDPM roof. Cost? $70.00 gallon and lots of labor.
โFeb-20-2015 07:35 PM
โFeb-20-2015 04:26 PM
enblethen wrote:
Kool Seal has a two product system.
Similar to the products from Dicor.
Dicor part 1
Dicor part 2
โFeb-20-2015 04:23 PM
smkettner wrote:
Kool Seal White Elastomeric Roof Coating:
Recommended for metal, concrete, foam, brick, flat cement tile, barrel cement tile and aged aluminum coatings
Note does not include rubber roof. Or it is a different product?
http://www.walmart.com/ip/Kool-Seal-White-Elastomeric-Roof-Coating/17210942
I would stick with Dicor. Possibly Eternabond along that long front seam. Old failed caulk must be removed as much as possible. Which means all of it.
I have read posts where people do Linex on the whole roof....
โFeb-20-2015 04:21 PM
โFeb-18-2015 09:03 AM
โFeb-18-2015 08:12 AM
Bud
USAF Retired
Pace Arrow
โFeb-18-2015 06:40 AM
โFeb-18-2015 12:12 AM
wealthwise wrote:Correct. Kool Seal or any other coating like it is not a total sealant. Even some that have used the alphatic undercoatings like Rhino or LineX have developed leaks. It sounds like a good idea-to have a monolithic coating that seals against all leaks but the usual homeowner solutions don't cut it. I have heard those that apply the specialized rubber roof coatings have success but when the products start approaching the cost of a total new EPDM skin, I think, what's the point? You could apply the Kool Seal product that is made for EPDM as it will lower temperature but that doesn't get all of those roof through holes sealed.westend wrote:
I'd suggest you remove the failed sealant and replace it with Dicor lap sealant or Eternabond tape. BTW, there is no good use for silicone based sealers on an RV.
You could try a fabric-friendly rust/stain remover on the interior. Don't know how successful that will be but probably worth a try if the ceiling only has a few spots.
So you are suggesting only Dicor or Eternabond and no Kool Seal?
โFeb-17-2015 06:32 PM
Bud
USAF Retired
Pace Arrow
โFeb-17-2015 05:49 PM
โFeb-17-2015 05:39 PM
rjxj wrote:
Throw the tape away. I would re do everything on the roof. If you dont remove the caulk, you at least have to make it good clean enough that the new Dicor self leveler will adhere to the old. Even if you try to remove it the surface will still be very irregular as it's just about impossible to get it all off.
If there are strips or flaps of sealant that are loose you want to remove that stuff. Clean it well and use a small scrub brush so all the cracks come clean than use a leaf blower or let it sit in the sun long enough to be sure all the cracks and crevices are dry before applying the Dicor. I would agree that now is the time to look at all the plastic up there and replace as needed. It wouldn't be surprising that the water damage is down the walls and possibly to the floor. It all depends on how long it has been like that. If you notice ridges or wavy sections under the membrane it's because the plywood is coming apart and buckling. If it's still all smooth that would be a very good sign that the damage is limited.
