So I got this old actual-metal tripplite inverter at a garage sale, with a broken 12v plug. I was gonna patch on a plug to it to test it out (or I could just pin the wire ends to terminals) but the input wires are both black.
Does it natter which is which? IOW, how hard should I try to ID these wires?
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
Thanks, guys. I don't want to let the smoke out :B
It's definitely an inverter. It says inverter on it, and has a couple ac outlets.
I can't find a manual online (tripp lite pv0536) but I can see red and black wires thru the vents, do I think if I get it open I will be able to ID which is which. And label them!
YES it matters. Get the polarity wrong and you will let out the magic blue smoke.
Regards, Don My ride is a 28 foot Class C, 256 watts solar, 556 amp-hours of Telcom jars, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
