Does anybody have this little dc/dc converter?
Salvo
I bought it after a link was posted here. I want to use it now but forgotten its spec. It's a great converter, operating in either constant voltage or constant current. The display outputs input voltage, output current, voltage and power.
What's the maximum input voltage and output current it can handle?
8 REPLIES 8
mlts22
You can buy it with a case as well, although it will need heat mitigation if working over 3 amps. If I did a 24 VDC system, I'd probably use one of these so I could step the voltage down to 12 VDC for a refrigerator (assuming the fridge doesn't have a 24 volt option.)
MEXICOWANDERER
I could use another dozen of these guys for my 10 watt 10 volt LED projects ๐Ÿ™‚
Every DROK bucker or booster I have purchased (perhaps 20+) have worked flawlessly and knock on wood none have come back for warranty.
Salvo
Thanks!
They say it's good for 5A. Not sure about that. The 3-character display unit is rated at 3A.
The LM2596 spec states 3A max.
MrWizard
Moderator
Moderator
looks like its this one
DROKยฎ LM2596 DC Buck Voltage Regulator 36V to 24V 12V 5V 3.3V 3V Converters Constant Volt&Amp 5-36V to 1.25-32V 5A 75W Step-down LED Driver Switch Power Supply Digital LED Voltmeter USB Output
Drock buck converter
I can explain it to you.
1997 F53 Bounder 36s
landyacht318
I have something similar that is voltage bucker only. I use it on a 180mm computer fan whose hub gets too hot at maximum speed and 13+ volts/ I limit it to 11 volts.
It has been in operation nearly continuously for over a year.
http://www.amazon.com/DROK-Switching-Regulator-Adjustable-Stabilizers/dp/B00BYTEHQO/ref=sr_1_4?s=ele...
enblethen
Looks like 40 volts
Drok Voltage regulator
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Learjet
is there a boost for low DC voltage? like there is with AC 10% or 20%
Sure would be nice to compensate for voltage drop to my trailer brakes.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
westend
Looks like a DROK product. It's probably an older product so some data mining might be necessary.
'03 F-250 4x4 CC
