โJul-07-2017 06:03 AM
โJul-08-2017 12:31 PM
โJul-08-2017 07:09 AM
ernie1 wrote:
dougrainer:
Is the 11 1/2" you're referring to at sea level? I was at 7,000 ft elevation and only had about 5" and the refer didn't want to light. Rv tech set the pressure to 16" and said at sea level it should be okay. What do you think?
โJul-08-2017 06:22 AM
โJul-07-2017 08:53 PM
โJul-07-2017 01:35 PM
โJul-07-2017 11:31 AM
Bud
USAF Retired
Pace Arrow
โJul-07-2017 10:41 AM
SidecarFlip wrote:
Forgot to add (getting old and forgetful), when you remove the top outside cover, look at the top of the boiler stack and you'll see a wire sticking up, clipped into a sheet metal securing clip. Pop it out and pull the baffle out and put it back in and pull it out..couple times.
Then clean the carbon off the baffle and vacuum up all the carbon and **** that has fallen from the tube the baffle is in. You need the chamber clean for the burner to heat the boiler properly and they all get carboned up after a while.
Working better on 110 than propane tells me the chimney tube is carboned up. Propane runs hotter than the 110 volt heating element, but the element is in next to the boiler tube and protected from the flame.
โJul-07-2017 10:35 AM
โJul-07-2017 09:41 AM
โJul-07-2017 09:17 AM
โJul-07-2017 08:37 AM
โJul-07-2017 08:29 AM
โJul-07-2017 08:25 AM
โJul-07-2017 07:57 AM
โJul-07-2017 07:53 AM
