Dometic Fridge not cooling
JCat
My Dometic Fridge stopped working yesterday, either on gas or electric. It is at least 10 yrs old.
Should I repair it or get a new one ?
Should I replace it with a residential unit that only runs on AC ?
I checked the recall list and I don't see the model or serial numbers on the recall list.
NDR1292
350 00046
I dont have much room for a residential as my furnace and water pump are under my fridge.
Thanks
JCat & PCat
2004 Mandalay 40D
CAT C7 350 HP
18 REPLIES 18
JCat
All lights are on, inside fridge and outside on the display.
No Yellow stuff in outside compartment/
JCat
JCat & PCat
2004 Mandalay 40D
CAT C7 350 HP
enblethen
I would have the existing one checked out before making a decision.
Does your display show any lights or codes? No would indicate no 12 volt control power.
Yes, it is possible that the control board is bad.
Look in the outside compartment for any debris or yellow substance. present would indicate a failure of the cooling unit. If cooling unit is bad, then a big decision. I personally would go with totally new unit. Replacing a cooling unit and you still have all the other components being old waiting for next item to fail.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
islandvagabonds
Go to "rvcoolingunit.com" . They have the new Amish cooling units. I have one. It works much better than the original unit and is cost effective.
2oldman
Depends on what's wrong with it. Maybe.. do you dry camp?
residential search in tech, followed by 'refer'
