Dometic Toilet (resolved)
Colo_Native
The toilet wont hold water tried the vasoline trick didn't work, made sure it's clean could it just be the seal, this thing is only 2 years old I would think the seal would last longer than that. Turns out that the valve has a little indentation about 6" down below the valve and it slipped out of that. Thanks everyone.
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
7 REPLIES 7
Jim-Linda
What Dometic do you have? The 310 has a seal that can be replaced in 10 min or less, no disassembly. Ck utube
SidecarFlip
Dennis12 wrote:
Try peeing in it and not flushing. Pee is thicker than water, it may hold. you can take care of the smell next.
That is funny there....
Stinks after a while too.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Ron_Nielson
Mineral oil works well for this purpose. Dirt cheap. Usually find it in the pharmacy section as it is also used as a laxative.
1492
Moderator
Moderator
Moved from Forum Technical Support
bob213
Never use a petroleum based product like Vaseline. Plumbers silicone is preferred. We put olive oil in ours when ever it's going to sit. Camco sells a product for toilet seals.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
Dennis12
Dennis Hoppert
Colo_Native
Whoops put I wrong forum Mod can you move it Thanks
Retired DFD
