Dometic toilet valave problem
Mayor30
We have a 2015 Keystone Cougar TT with a Dometic toilet. Must have not gotten all the water out of the valve and it froze and broke. I got a replacement valve and out it in. The old valve worked by stepping on it all the way to flush and part way to fill. The new valve opens the flush mechanism no matter how you step on the flush valve. Any suggestions?
16 REPLIES 16
dougrainer
Mayor30 wrote:
dougrainer wrote:
I should have explained the water valve mount screws. When replacing the original valve, they supply 2 screws to secure the valve tightly to the housing. IF you did not install those screws, it is possible that when attempting to gently push the pedal down, the valve is moving rearward slightly and that causes the water valve to not open until you push more firmly, which will open the Ball valve slightly. If you did install the screws and you did NOT fiddle with the Foot lever, then I would think the new valve is defective and you need to replace it. Doug
OK, that may be the issue. I did not install the screws because the old one did not have screws in it.
Correct. That is why they supply the screws. Doug
Mayor30
dougrainer
Grit_dog
Navigator
Navigator
dougrainer wrote:
wa8yxm wrote:
NO. that is not a valve. that's a "T" or to be more precise a :Y: fitting
You just cannot help but being WRONG. That is a Toilet Valve. Doug
Lol, you beat me to it!
dougrainer
IF the model 310 which is what the Valve listed is for. You push down Slightly to fill and then all the way to open the ball valve and Flush. To the OP, There were 2 screws supplied with the new valve. Those screws are NEEDED to be installed after the original valve is replaced. They keep the valve secured in place as the original plastic clips will not hold the valve securely in place. This style replacement valve should NOT have affected the operation of the ball valve, but if you state that no matter how gently you push down, the ball valve opens, then I would remove the new Water Valve, put vaseline on the end of the stem going inside and then retry. Doug
dougrainer
Dusty_R
We had the valve break in the toilet in our mh, don't remember why/how, but were told that a new valve was not available, so we bought a new toilet. Then found and bought a new valve. So for the last couple of years we have a new RV toilet, still in box, sitting in our garage.
wa8yxm
Bobbo
Mayor30 wrote:
This is the valve
You posted a website url with the img labels.
https://www.ecrater.com/p/32374362/dometic-sealand-vacuflush-toilet-water
Bobbo and Lin
Mayor30
This is the valve
wa8yxm
Try lifting to fill. not pressing down.
As I recall the 310/311 are supposed to lift to fill stomp to flush.
opnspaces
Navigator II
Navigator II
Are there two cables on the pedal and you have them switched on the valve? So a push to fill is hooked to the flush and vice versa?
Try taking the replacement parts off and look at them again to see if you might have put them on wrong.
MFL
Nomad II
Nomad II
It seems you did not install/hookup properly. If you compared old valve to new, it should be the correct one.
A common model 310 Dometic would operate as described, a light push downward will fill bowl, full down to flush.
Jerry
BurbMan
All the Dometic foot flush toilets I've seen you lift the foot flush lever UP with your toe to activate just the fill valve without opening the dump valve.
I just replaced mine with this valve.
