Drinking water hose
Eyeland
Been fulltiming for 9 yrs and been using the white drinking water hose that most of us use. What a pain!! Just try to roll it up to store away. You know the problem.. Tried the type hose that extends with the psi of the water and then shrinks after the water is turned off. Worked well until blow out in a month. You guys got any suggestions for Drinking water hose?
22 REPLIES 22
NanciL
I have just this year, after fifteen years of RV'ing switch to 25 foot long hoses.
I am keeping four of them with me.
Much easier to roll up a 25 footer then a fifty, and if I need longer, I just connect two together.
Jack L
Jack & Nanci
Ron3rd
doxiemom11 wrote:
We don't seem to have problems with our white hose. Maybe you need a new one that is higher quality??? Don't know what you had but there are different grades of hoses.
X2, there are good quality white RV hoses, but they are not cheap. Expect to pay 30 or 40 bucks for a good one. I bought a couple of the cheap hoses from WalMart and they're total junk and kink at every opportunity. I like some of the new ideas posted above and might try one of them out.
Equilizer Hitch
Honda EU2000
ol_Bombero-JC
Some of us aren't - "most", LOL!
Purchase a *quality* hose from these folks - available in lots of lengths. Couplings are *spectacular* (brass or stainless).
RV Water Filter Store
Scroll down the left side to "Custom Quality Hoses"
They are!
Once you've tried one of their hoses - you will understand why the rest are junk!.:W
On edit: I see "accsys" already offered the same advice / suggestion.
So, I'll add: Quick delivery!
tenbear
I have 3 hoses, 10', 20', and 50'. I use the shortest one I can, usually the 10' one. Easy to roll up and drain. The 20' is pretty easy too. Rarely do I have to use the 50'. I keep them all rolled up with the ends of each hose connected so they are each sealed, in a tub.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
down_home
tvman44 wrote:
My white hose is almost impossible to handle if the weather is the least bit cool. ๐Ÿ˜ž
Had that same problem when it got below 113 in West Monroe. ๐Ÿ™‚
tvman44
Papa Bob
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
tvman44
My white hose is almost impossible to handle if the weather is the least bit cool.(
Papa Bob
wa8yxm
I would stick with the white hose.. If it's hard to roll up warm it up a bit (Run hot water through it if you have to.
Also, a hose reel makes it easier to roll and unroll.
Bumpyroad
I have seen several hoses of different colors all claiming to be fine for drinking water. I mean, they put a blue streak on standard RV water hoses.
bumpy
RayJayco
I believe that white hoses were originally designated as safe to drink from due to being free of lead... (although I have drank from many garden hoses years ago...)
If the hose is not white, I would read the label to see if it states that it is safe for drinking water, if not, well... Convenience or health, your choice. (Occasionally drinking would probably not be a problem, although lead does typically stay in the body and build up over time. When will your body hit the amount to cause brain/nerve damage, is the question...)
Inquiring minds want to know...
Bumpyroad
rk911 wrote:
sure. I have two 10-ft lengths of white drinking water hose and another 25-ft length on a hand-held reel. 8 times outta 10 I can hook up to the fresh water spigot with a single 10-ft length. if that's not enough then I add the second 10-ft length. only rarely do I need the 25-ft reel. but when I do the hose rolls up quite easily on the reel.
basically what I do. did buy a long non-kink hose also.
bumpy
camperpaul
You can avoid the mess and the kinking of both hoses and cables by using this method.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
accsys
The RV Water Filter Store is the go to place for everything concerning hooking up to water. They have the Watts pressure regulators as well a some great hoses that will last and work like you want them to. Under the Systems and Components menu on the left side you will find the link for Custom Quality Hoses. Their hoses are not cheap but are worth the money in the end.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
doxiemom11
