โJul-03-2017 06:51 PM
โJul-04-2017 10:29 AM
j-d wrote:eHoefler wrote:
The capacitor is for the compressor, not the fan. Chances are the fan has a bad bearing and is not spinning freely.
Untrue and True!
Untrue: The FAN does use a Capacitor. It's a RUN Capacitor only. Compressor uses a RUN Capacitor as well, and in addition it MAY have a START Capacitor.
So, Always RUN Capacitors, for BOTH "motors" (Fan and Compressor). Some A/C's use two separate Capacitors, but many such appliances use a Two-in-One Capacitor. Usually around 05 mfd for Fan and about 35 mfd for Compressor. Easy to tell. The two-in-one will have three sets of connections. Singles will have only tow per capacitor.
Then IF there's a Start Capacitor, it is connected across ONLY the Compressor Capacitor (or that part of a two-in-one).
TRUE: Heartily agree the Fan Motor Bearings could be sticky, so the idea of rolling it over by hand to check, is a very good one. Those fan motors have very, very, little starting torque. Doesn't take much to keep them from being able to spin up.
โJul-04-2017 07:49 AM
โJul-04-2017 06:43 AM
โJul-04-2017 06:13 AM
โJul-04-2017 05:59 AM
โJul-04-2017 04:47 AM
โJul-04-2017 03:53 AM
โJul-03-2017 07:29 PM
