โFeb-21-2014 06:35 AM
โFeb-21-2014 03:17 PM
OH48Lt wrote:As I understand it, that is what Buddy Bearings are for, not EZ Lube bearings.
I used them on a 5ver -once. Never again.
Called Dexter about this, they said they wish RV manufacturers would not use them. They are intended for use only on trailers that get the axles submerged in water, such as a boat trailer.
I replaced the seal I blew out using the hand-pump-and-spin method, and hand-packed them after that experience.
โFeb-21-2014 03:05 PM
โFeb-21-2014 02:59 PM
โFeb-21-2014 02:18 PM
โFeb-21-2014 01:59 PM
beemerphile1 wrote:
You just need to use trigger control, like anytime you use any gun.
โFeb-21-2014 09:56 AM
โFeb-21-2014 08:53 AM
โFeb-21-2014 08:43 AM
โFeb-21-2014 08:40 AM
โFeb-21-2014 08:21 AM
โFeb-21-2014 08:20 AM
โFeb-21-2014 06:55 AM
My Rockwood came with E-Z Lube axles (not to be confused with Bearing Buddies).
Has anyone actually used this feature?
(Alert: I'm a retired ASE certified Master Technician. Please, there is no need to explain blowing out hub seals, the wonders of inspecting and hand packing bearings, the opportunity to look at the brakes, etc.)
Teach
โFeb-21-2014 06:52 AM
โFeb-21-2014 06:50 AM
โFeb-21-2014 06:46 AM
