Access to the water pump is via a panel at floor level of the rear storage compartment of my 2014 Coachmen 21QB motor home. The panel is about 6 inches tall and about 20 inches long. It's secured by 4 of the ubiquitous #2 square head screws. It's also recessed about 2 inches behind the panel above it.
The screws are difficult to reach, the holes are chewed up, and I will likely winterize 3-4 times a year since I travel in the winter.
What's a decent alternative fastener that I could use to replace the screws?
I'm toying with the idea of some small ceramic magnets glued in strategic places, so the panel could be popped off quickly. Any other suggestions?
Plan A was to add an access port
like this one,, but the shape of the panel makes that not feasible.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
