Electrical issues
mbowie1034
I have a 2013 Cedar Creek 36BHS. Currently camped in Georgetown, KY. Started having issues with the refrigerator blowing no cold air but still running. Then, we had to change sites; started setting up, lowered jacks, extended slides then different functions started shutting down. Now, the frig is still hot, jacks, awning, and slides don't work. Had a tech come out, diagnosed as a converter issue but took converter to CW and tested fine. Something is shutting down the converter right after it's plugged in- any ideas? I've checked all known fuses and no breakers are tripping...thanks!!
11 REPLIES 11
mbowie1034
I found the problem! The power distribution block I referred to had small, plastic buttons on the hot side that apparently control the other side. Pushed them in and everything come to life- except the refrigerator; think that will be another issue..
1492
Moderator
Moderator
mbowie1034
Okay, I have 13.3 coming off from the converter; batteries are reading 13.3; cable from battery to Power block is 13.2; post at top of block which leads to control board that has everything listed that's not working is dead. Somehow power is not getting up to the top part of this block. All other posts on this block are live except the two on the that top side. I would post a picture but I couldn't figure out how!
Yes, frig is a house frig that runs just off of D.C. Current.
Old-Biscuit
Fridge not blowing cold air but running???
DO you have a residential fridge OR an RV electric/propane fridge?
Jacks, awning, slides (possibly fridge if RV type) don;t work.........ALL need DC power
Converter..
When plugged into shore power (or gen)
120V AC input..13.2V DC output
Supplies the DC System PLUS charges/maintains battery
No converter function batteery supplies DC System until it goes dead
Simple voltmeter test......
DC Voltage AT converter with AC power connected (shore power ON and Circuit breaker to converter ON)
13.2V DC output to battery (minimum)
DC Voltage check at battery S/B 13.2V DC (minimum also)
Converter DC output low....replace converter
Got good DC at converter but not at battery..then check for blown fuses in battery POS cable to converter
Hookup portable battery charger and SAVE battery from death by recharging it/maintaining charge until you replace converter
Sandia_Man
Without a voltmeter any diagnosis will be just a guess. I would imagine even the least experienced RV tech would know how to at least do basic voltage checks at the converter's input and output. Many of the items you mentioned require heavy current draw and are many times wired directly to your battery which sounds very depleted at this point.
Run down to Wallys or Harbor Freight and pick up a cheap battery charger to get your batteries back up, for a few bucks more grab a voltmeter too. Let batteries charge for awhile hopefully this will restore some DC items, heavier current draw items will require a deeper charge on the batteries to function properly. There are fuses located near the battery, use voltmeter to trace circuit.
K_Charles
Was it a tech or a parts replacer? The converter should have been checked in the camper, if check OK then no need to remove it.
kerrlakeRoo
Time for a long afternoon with a voltmeter and a friend to flip breakers.
As was said before check battery voltage, at batteries, nothing running.
If Voltage is 12.5 or higher, then charging should have happened either from the converter or from to vehicle. Try running TV for a half hour or so, with jumpers to your battery preferably. Get the voltage up to 13.4 or more and then check operation of slides awning etc.
ScottG
Nothing in the rig has the ability to shut down the converter at will.
I would trust the tech before I would trust CW to test a converter.
enblethen
Did tech verify power to the rig?
Plug into TV and see if 12 volt items work. Start TV!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Toddupton
You could use a better charger for now to get by. What is the output to the battery?
Mandalay_Parr
Best have electrical person use their meter to diangnose. A number of things are in that circuit.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
