We have an electrical problem and I know almost nothing about electricity, so here it goes with my description of what's happening.
We're staying at Freedom Shores in Isla Aguada, Mexico. Yesterday, when we arrived, I plugged the RV into shore power (15 amp). Everything in the RV ok: microwave came on, fridge switched to AC, phone started charging.
Ten minutes later, I go inside the RV and notice the microwave being off. The rest (fridge, phone charging) still ok and on electric. Strange.
I find my multimeter and test the 15 amp campground outlet: around 230 V! I unplugged shore power and found a different campground outlet that shows around 110 V to plug into.
What is the current situation?
- microwave 'dead' (and apparently the microwave fuse is built-in, so I don't know how to check if that's the issue)
- fridge on AC (not on gas, which it's on when we're not plugged in)
- outlets in RV working (to charge phone)
- fan and AC in RV working
- I checked the RV battery with my multimeter and in early afternoon it showed 12.70 V; in late evening 12.69 V
- I reset all the breakers in the RV: nothing changed.
- I also visually checked the RV fuses: nothing looks burned.
Any idea what is wrong?
Being in Mexico limits the availability of parts or experienced RV electricians, added up with my limited Spanish knowledge ...
Any help is greatly appreciated!
Thanks,
Jorn
