electrical
terrybeckleyone
Hello! Thanks in advance for the help!  I am in a vintage 1987 Mini Winnie Winnebago, Toyota chassis. My nephew basically rebuilt the house for me, doing many upgrades. My biggest issue right now is that he wasn't sure how everything should be tied together per se, electrically, and also has not been able to supply me with a complete flow chart of how he wired it. I am hoping someone can develop a detailed flow chart diagram for me to put to use in revising anything I need to.
I have 8 solar panels on the roof, 130w each; An MPPT charge controller; a 2000W pure sine inverter; a tankless propane water heater; a Velit 12v rooftop a/c unit; 4 LifePo batteries, 150ah each; a 75 amp charger/converter; a transfer/switch box; air bags on the rear. I thoink that is everything that he changed from the original equipment...  Thanks again for any assistance!
Terry Beckley
6 REPLIES 6
Grit_dog
Navigator
Navigator
The โ€œnephewโ€ must have fixed it for herโ€ฆ
must be that time of year. I feel bad for the motorhomeless.
Not fixed yet, just frustrated that you folks don't seem to understand the "ask." Is anyone able to diagram for me, as if it wasn't yet set up, how it SHOULD be. I then plan to have a qualified person look my rig over and "correct" it. The issue I am having is not significant because I am able to be plugged into shore power, but plan to be boondocking extensively. I hope that clarifies it sufficiently.
You still need to have a qualified person look at because your ask is still impossible. You can find basic wiring diagrams for Rvs all over the net with solar converters, batteries etc. But it all has to be compatible. Even RVs coming off the same assembly line can be wired a little differently. You have a 38-year-old Rv with some aftermarket parts that someone has already done some wiring in it for you. Not trying to be crass, I understand your issue, but armchair responses on here aren't going to help you much with your scenario. You need someone to look at your rig, understand how it's wired now, lay out the equipment etc etc. It's not overly complicated, just that your RV is pretty unique given the age and new equipment. Even production RV's wiring is often a mystery how they did it. Google wiring diagrams for RVs with Solar, your batteries, etc. Also, do you have a generator. Not sure you'll get much run time out of an AC on batteries.
Yes that helps a bit but now more information is probably needed. By my understanding you want someone to draw a basic diagram of not your current system, but of how a system should work.  Per your original post you have :
  •  8 solar panels on the roof, 130w each; An MPPT charge controller and a 2000W pure sine inverter, 4 LifePo batteries, 150ah each; a 75 amp charger/converter; a transfer/switch box. Is there a working generator? Are you looking for a diagram for that? Are you able to ask your nephew if the solar panels are wired series or in parallel? Are they 12v or 24v panels?
  • A Velit 12v rooftop a/c unit. Does that unit currently work on shore power? Are you hoping to make it also work on generator or solar? (FYI running the AC on solar is pretty much out of the question)
  • Air bags on the rear. Are the airbags currently working?
Grit_dog
Navigator
Navigator
lol, you have the vehicle. Make a diagram of what he did.
Presume you donโ€™t have issues because you didnโ€™t say that.
bid_time
Nomad II
Nomad II
Your โ€œaskโ€ is impossible for anyone here sitting at home in their armchair. If your nephew who did the work canโ€™t tell you what he did, then surely we canโ€™t tell you what he did.
