Erratic Tank Sensor Readings
skidooman93
Does anyone have a fix for erratic tank sensors. I have one grey tank sensor, and the black tank sensor that cant seem to give consistent readings. The coach isn't very old, 2014 im the second owner.
2015 Ram 2500 SB 6.7 Cummins, 68RFE Rear Air Suspension
2015 Ram 2500 SB 6.4 Hemi 4.10's Rear Coil Springs (Sold)
Anderson UCH
2014 Open Range 367BHS
1 wife, 1 Son, 1 Daughter, 1 Red Lab that wont come in the camper because hes a big baby, so he stays home.
7 REPLIES 7
Dusty_R
Check out SeeLevel.
http://www.bestconverter.com/SeeLevel-Gauges_c_108.html
Dusty
Dusty_R
Check out SeeLevel.
Dusty
doxiemom11
Normal in any rv. You can tell when they are getting full without the sensors. The black will make small burping/belching sounds and the grey would make the drain slower and then back up in the shower.
SoundGuy
Try a dose of Walex Commando ... I do a couple of times each season and have no tank monitor issues at all. :B
2012 Silverado 1500 Crew Cab
skidooman93
Thanks red it, will give it a try!!!!
Anderson UCH
skidooman93
I searched "erratic rv tank sensors" on google and got basically nothing lol
Anderson UCH
jplante4
Search here or google "The Geo Method". Discussed here at least 10 times a year. Basically, Dawn blue and Calgon with water in a tank slicks things up and rinses the crud off the tank walls.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
