โMay-29-2018 01:07 PM
โJun-02-2018 12:42 PM
โJun-02-2018 12:40 PM
โJun-01-2018 11:23 PM
โMay-30-2018 09:28 AM
โMay-30-2018 07:51 AM
โMay-30-2018 06:22 AM
โMay-30-2018 05:31 AM
kampinguru wrote:
maybe spider webs in the venturi tube. I just had a similar problem and took the compressor this past weekend and blew everything out well. Runs great now with no issues.
โMay-30-2018 04:58 AM
โMay-30-2018 04:15 AM
โMay-29-2018 02:02 PM
wrgrs50s wrote:
If you shut off your propane bottles, then turn them on when you get to the campsite, the slight pressure loss can cause a pocket to make the gas valve hesitate causing irregular pressure. Once the line is fully pressurized then the valve will provide continuous operation. Most time a quick light of a stovetop burner will allow the pressure pocket or air gap to pass and then you will have full pressure to the gas valve at the water heater. Try this next time, or before going to a dealer.
โMay-29-2018 01:53 PM
boogie_4wheel wrote:
Open the cover and try it. Mine did the same thing. I drilled a few holes along the lower-left of the cover. Problem solved.
While it isn't right, it worked. I visited a local parts and repair shop one the issue and two guys said that it was a 'common' problem on the suburban.
While on the road I had learned that it consistently worked fine with the door open, but it was a 50/50 with it closed. I had cut and bent the bottom corner to allow more fresh air in, and then replaced with a new cover and added the holes for a cleaner look after the trip.
โMay-29-2018 01:28 PM
โMay-29-2018 01:23 PM
โMay-29-2018 01:18 PM
