Eternabond Failure
TurnThePage
I have to eat a little crow. A while back someone posted that Eternabond could trap water behind it, thus causing rot or some other issue. I cockily responded with, How could water get behind it? Well I found probably half a cup of water trapped behind Eternabond tape wrapped around my fridge vent. As I kept searching, I found that a good amount of the tape had dried out and literally rotted away. In the attached photo, you can see where I used left over tape to secure solar cable to the roof. Look how it cracked open. If you look close, you can see tiny cracks all over it. Yeah, it's a mess too. :B
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
27 REPLIES 27
TUCQUALA
Prepping the surface won't have any effect on the cover cracking and splitting. Same thing happened to sections on my solar cables in just over one year!! Believe it or not, 1+ year!!! The tape was still stuck to the roof just fine, but the outer surface was sun rotted and cracked, and peeling off. Leaving the adhesive base still there! Probably wouldn't leak as such, but that expensive **** should last longer if you want to believe the name!!!
Package was "Eternabond", but who knows if not a chinese counterfeit??!!
I can see adding sealant along the sides of tape if you are really anally retentive, but you shouldn't have to cover the tape to make it last.
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
3_tons
I applied it around the around the skylight over the shower and it created a dam and water leaked inside...I wont do that again.
landyacht318
In applying anything to a surface os something else, it is all about proper prepping of the surface for proper adhesion.
But perhaps people prefer to believe marketers lies, combined with price and internet rumor, outweigh logic, and uncommon sense.
rexlion
Well, doggone it! With a name like Eternabond, I thought it might last longer than the trailer itself! What's in a name...
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
WyoTraveler
Everyone that I have talked to says you must properly prep. After applying anything periodically check it for cracks or damage. If you see cracks you can put self leveling dicor on top of cracks. If it looks bad remove and replace. I inspect a couple of times a year.
Kayteg1
I think I removed about 30 feet of eternabond from my Fleetwood that PO slapped here and there.
The dryrot behind it was huge.
Even when aluminium beam under the slide broke the weld - PO slapped eternabond on crack.
IMHO that stuff, just like silicone caulk should not be sold to aging men.
drsteve
12 years? Well, nothing lasts forever.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
CaLBaR
I have had my eternabond on the front cap seal start doing the same thing. Fortunately I caught it a few weeks ago but also had a bit of water damage. Mine has been up there about 8 or 9 years. Mine is in the same place over the dicor caulking. I think that may be the issue too. Other places look fine.
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
time2roll
Hard to tell depth in the close-up picture. Was the EB stretched to get down in that valley that was holding water?
WILDEBILL308
Well one more reason to do a yearley inspection and re seal of your roof.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
TurnThePage
It's probably been up thete 12 years. Why would roof prep or, lack of, cause the tape to dry out and crack?
2015 Ram 1500
newman_fulltime
way the roof looks it wasnt properly prepped
gbopp
How long was the Eternabond on the roof?
Did you apply it, (or can you blame it on someone else?) 🙂
