โJun-11-2014 04:24 PM
โAug-04-2014 10:26 PM
thmitch79 wrote:
Anyone do their own brakes? I have a 2003 Southwind, F53 chassis with 19.5" tires. I do the brakes on my cars and trucks but have never attempted to do a motorhome. Besides being bigger, what else should I look for? I am going to make the attempt soon.
โAug-04-2014 03:00 PM
โJul-23-2014 02:13 PM
โJul-22-2014 08:53 PM
John Wayne wrote:
Fleetwood 99 your right I stand corrected it's not 79 lb/ft it's 85 lb/ft. The following is from the Ford Motor co. 2001 workshop manual. #3.While rotating the wheel , tighten the adjusting nut to specifications as illustrated (114Nm (85 lb/ft) ) to seat the bearings. #4 Back off the adjusting nut until loose. #5. Finger- tighten the adjusting nut. Final bearing adjustment end play must be within the specifications as illustrated (0.000-0.125 NM / 0.000-0,005in.) The final adjustment must not result in a preloaded bearing. #6 If cotter pin hole lines up with slot in nut, insert and secure the new cotter pin. If it does not, advance the adjusting nut to align a slot with the first available cotter pin hole. Insert and secure a new cotter pin. #7 Install the gasket and hub cap.
โJul-21-2014 10:58 PM
โJul-12-2014 12:11 PM
โJul-11-2014 12:27 PM
John Wayne wrote:
Buy new seals for the front and repack the bearings while your at it. I think the preload on the bearings is like 79 foot lbs. if I remember right. Wheel lug nuts are 150 ft.lbs.
โJun-12-2014 02:53 AM
โJun-11-2014 10:37 PM
โJun-11-2014 06:49 PM
โJun-11-2014 06:26 PM
โJun-11-2014 06:10 PM
โJun-11-2014 05:11 PM
