fan not cutting off on my front ac\hp,
rbhjhh
the fan on my air conditioner/hp just started running all the time. it is a duo therm, everything else is working fine.
any sugestions
10 REPLIES 10
dougrainer
rbhjhh wrote:
where is the best place to buy the parts i need for my duo therm 630035.321. i think it is penguin
Thanks
Yes, it is a Penguin. HOW do you know what parts you need???????? Doug
rbhjhh
Thanks
dougrainer
rbhjhh wrote:
I have 2001 monaco diplomat, duo therm air conditioner /heat pump.
ONLY 2 things will cause this on your Dometic system
1. The ZONE on your tstat is NOT set to the one on the affected AC unit. Make sure you can see BOTH Zone 1 and 2. 2001, you may have the original 4 button tstat instead of the updated 5 button. IF you have a ZONE button you have the 5 button. IF you have NO Zone button you have the original 4 button. If you have the 4 button, do you know how to change Zones?
2. Your upper main control board is bad, it will need replaced. Doug
ernie1
The relay that is powering the fan has the contacts welded together. Get another relay.
j-d
Better if you can post the DuoTherm model, and that of the Thermostat as well.
rbhjhh
bullydogs1
What brand is your AC?..and your coach...This happened to my wireless carrier unit and I found out that it didn't like the wifi hot spot close to it...Once I moved it...it resolved itself..
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
rbhjhh
It is set on auto, even when I turn the termostat off the fan runs, I have to click the breaker to get it to stop. Thought it might be thermostat.
96Bounder30E
Moved from Class A Motorhomes
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
sch911
Check thermostat, make sure it's set to Auto and not to On.
OEM Auto Engineer- Embedded Software Team
