โJul-12-2019 11:51 PM
โJul-14-2019 01:07 AM
โJul-14-2019 01:01 AM
joerg68 wrote:
The pin is in the upper surface of the fan housing, the side that faces the cover.
When the cover is lowered, it depresses the switch pin and cuts power to the fan to prevent it from running with the cover closed.
But your issue is with the lift motor, not with the fan itself, right?
I am not sure if that cutout switch has any connection to the circuit of the lift assembly. I just mentioned it as it is the one thing that gives problems pretty frequently.
Like I said before, your description sounds more like the lift motor is getting overloaded. But I have never had that type of Fantastic Fan myself, only the manual lift version.
โJul-13-2019 10:29 AM
โJul-13-2019 09:18 AM
2 many 2 wrote:joerg68 wrote:
There is a cutout switch that turns off the fan when the cover is closed.
That switch goes bad sometimes.
This happens to mine every once in a while, that pin switch sticks or has enough dirt and corrosion on it so it does not make contact. All I have to do to un-stick it is open and close the lid manually a couple inches a few times and it starts working again.
If that does not work, if you remove the screen, feel around for the switch and push it up and down a few times. Make sure to turn the fan off first :E
Please let us know what you figure out.
โJul-13-2019 09:15 AM
It may or may not have something to do with your problem.
It is a pin that gets pressed down by the cover when it is lowered. Fairly easy to bypass temporarily for testing purposes.
But tbh your description sounds more like an overload issue with the lift motor. Have you tried to grease the lift assembly? Or maybe something has become unaligned, a screw turned loose or something, and now the motor does not have enough power after the first turns? If that is the reason, and you crank it up further manually, I would expect the motor to not be able to crank it down either.
โJul-13-2019 09:02 AM
โJul-13-2019 04:01 AM
