Apr-10-2014 03:21 PM
Apr-12-2014 06:16 PM
Apr-12-2014 03:59 PM
Apr-12-2014 10:20 AM
mena661 wrote:What you're missing is that shorts are abnormal and don't obey any rules or preconceived notions. Inverters may/may not have any fuses to protect the heavy DC draw electronics and they don't need to because the fuse should be near the battery. But if it does have a fuse what if the short occurs between it's fuse and the terminal lug? You don't want the wiring to overheat and cause a fire or cause the battery to overheat and be destroyed or cause a fire.CA Traveler wrote:Fusing is for protecting wire. Regardless, this does not make any sense (at least not to me) if you have properly sized wire. In a 300W inverter, the max it draws is 30 amps from the batteries (maybe it can draw up to its surge rating IDK). If I have wiring that can accommodate 100-380 amps (this is my setup), how is a short going to do anything to the wire? If the equipment shorts internally, it has fuses and protection circuits to handle that. Not to mention, shorts ALWAYS lead to an open and usually in a short period (pun) of time because internal circuitry is not designed to run over its design parameters. I'd be more worried about the equipment catching fire than wiring melting.
Fuses protect the equipment and the wiring. Wiring can develop a short and you certainly want a fuse to protect it and the equipment.
Apr-12-2014 09:03 AM
red31 wrote:
Should jumper cables be fused?
Apr-11-2014 09:41 AM
BFL13 wrote:I remember that sort of and someone explained very well why there should be a main battery fuse. My "inverter fuse" is actually near the batteries and is an ANL 60 amp. It was initially sized for the converter. If I get that 2000W inverter then I'll change the fuse to allow for that.
A while ago we had some threads about ISTR Xantrex saying in their manuals that you had to fuse to the battery shorting ??
Apr-11-2014 09:18 AM
Apr-11-2014 08:50 AM
Padlin wrote:Hi Bob & Deb,
dual 6V batteries, 230A. 1500w Inverter, 125A. Solar Controller, 30A. Converter, 55A
Connecting the battery - via 2awg to a 500A shunt to feed a Trimetric Battery Monitor
Battery + via 2awg to a Main fuse.
Main fuse to 3 way power distribution block.
Fuse for inverter leg 150A, 4awg
Fuse for converter leg 60A, 8awg
Fuse for solar controller leg 40A. 8awg
Question, what size should the Main fuse be? do I even need a Main fuse?
Apr-11-2014 08:41 AM
Apr-11-2014 08:28 AM
Apr-11-2014 07:36 AM
smkettner wrote:The main fuse needs to protect the inverter draw plus all other draws (lights etc). Most likely 200A will handle the loads, perhaps 150A also.Padlin wrote:Let the inverter fuse also be the main fuse. I would probably go 150 or 200 amp.
You will not have much if any inverter surge issue in an RV.
Apr-11-2014 07:21 AM
Apr-11-2014 06:37 AM
BFL13 wrote:Same here as you've seen many times from me. I do have a fuse on my inverter though. I just don't understand why I need one. It's wiring is #2 to 4/0 to #6 for a 300W inverter. That unit won't ever draw that much current, not without burning itself out in spectacular fashion. Maybe a failure could cause an inverter to run at it's surge rating?? Or maybe the inverter manufacturers are doing a CYA in case someone uses the wrong size wire?? I could understand that. I've seen many times here where the manual says 4/0 and the person installs #2 on a 2000W inverter. Yeah, you'll need a fuse with that install if something goes wrong.
I find it all very confusing
Apr-11-2014 06:25 AM
mena661 wrote:RJsfishin wrote:I agree with this assessment. The inverter is only going to draw up to its rating and if your wire is enough to handle the rating then you don't need the fuse.
You do not need a fuse in the inverter line. Altho if you lack confidence in your installation being fool proof as far as short circuiting, then maybe "you" do.
Apr-10-2014 10:57 PM
