Jun-28-2021 09:13 AM
Jun-28-2021 05:23 PM
valhalla360 wrote:Mike134 wrote:
I remember my first trip to the boundary waters canoe area in Minnesota.
Us city kids were stunned when the outfitter told us to drink the lake water no filter needed.
I must say we had no issues.
Works great...until it doesn't.
Jun-28-2021 04:48 PM
Jun-28-2021 04:41 PM
When consumed in contaminated water, the microscopic parasite Cryptosporidium can cause symptoms of stomach cramps, diarrhea and fever. Now, researchers reporting in the ACS journal Environmental Science & Technology have detected evidence of the parasite in about 40 percent of surveyed wells in public water systems in Minnesota -- even wells not influenced by surface water. The team emphasizes that they don't know whether the parasite levels are high enough to actually cause health concerns.
Surface Water. Cysts have been found all months of the year in surface waters from the Arctic to thetropics in even the most pristine of surface waters. Occasionally, seasonal variations are reported. Cyst levelsare generally higher in rivers or streams influenced by agricultural (e.g., cattle or dairy farming) or residential(e.g., sewage discharges) activities. Cysts occur in surface waters throughout the year. In North America, levelsare generally higher in the late summer to early winter. Generally, no relationship is seen between cyst levelsand bacterial indicators of water contamination. In the United States, levels of Giardia in water are somewhatlower than Cryptosporidium; in Canada, surveys have found higher levels of Giardia than Cryptosporidium.
Jun-28-2021 03:15 PM
Jun-28-2021 11:35 AM
Jun-28-2021 11:31 AM
wildtoad wrote:agesilaus wrote:.
Use a in line filter on the fill hose. I assume this lake water has been checked by the county health dept. It seems to be an unusual water source.
Many people who live on lakes pull water from them for both irrigation and household use. To your point, having the water tested periodically is a good idea. The same holds true for the millions of households the get their drinking water from a well. One should always use a filter at CG’s regardless of the water source. Never know when a water line may break.
Jun-28-2021 11:16 AM
Jun-28-2021 10:04 AM
Jun-28-2021 10:02 AM
Jun-28-2021 09:51 AM
wildtoad wrote:
If you’re worried about sediment get a good filter that takes out small sediment. Personally I’d put a whole house filter between the well pump and the house. Sediment won’t do good things to ice makers, water heaters, and so on. They are very cheap and effective.
Jun-28-2021 09:49 AM
Jun-28-2021 09:47 AM
Jun-28-2021 09:35 AM
agesilaus wrote:.
Jun-28-2021 09:30 AM
