I often state that if you have a Magnetek 6300 series EVEN IF IT IS BRAND NEW and just installed .... You should upgrade
I recomment the Progressive Dynamics 4600 series, I think they do make a 4645, from Best Converters (or best converter, one is an audio store, the other RV store) you need to add one jumper wire.
The Magnetek 6300 is a feroresonnant converter, no voltage regulation to speak of, it is widly known as a battery killer and rellly needs an upgrade. It also does not work withotu a battery.
The lights, water pump and loads of that type do not mind unfiltered DC, radios and thigns that need FILTERED DC hook to the battery side of the converter and the Battery acts as a filter.... So you do not need a filter, Just a battery, and you will need a new battery often with that convwerter.
So Upgrade. 2 batteries = a Progressive Dynamics 4600 and change, lots of change.
