โSep-03-2013 08:20 AM
โSep-04-2013 06:55 AM
โSep-03-2013 07:13 PM
โSep-03-2013 05:39 PM
wa8yxm wrote:
Tires come in two flavors for this post, HIgh pressure (IE 100 PSI range) and low (Less than 50)
Low pressure tires on cars often have plastic camps on the tire valve stem, HIGH are supposed to have metal caps with a sealing ring, JUST in case the valve core does not seat properly.
My guess.. The valve stem was a tad loose (The nut at the base of the stem) and that is where it leaked.. This is, however, a guess, nothing more.
Suggestion: Dorian Pressure Pro or Pressure Pro or another Tire Pressure Monitoring System..
Ideally you should check your tire pressure quite often.. With many of these systems you can "Check" it from the driver's seat while doing 55mph every few minutes.. and if a tire goes low, IT screams at you "FEED ME AIR" like you would not believe.
The cost of such a system..... Less than your new tires.
โSep-03-2013 04:55 PM
โSep-03-2013 04:38 PM
โSep-03-2013 12:56 PM
โSep-03-2013 12:15 PM
โSep-03-2013 12:03 PM
โSep-03-2013 11:53 AM
โSep-03-2013 11:49 AM
โSep-03-2013 11:41 AM
โSep-03-2013 10:28 AM
โSep-03-2013 10:14 AM
โSep-03-2013 10:10 AM
Kennedycamper wrote:
2 things, First your post makes a compelling argument for doing a practice tire change in your own driveway before the first trip. Second, Tire Pressure Monitor Systems may not be as worthless as their detractors seem to think.
