โDec-12-2020 04:57 PM
โFeb-06-2021 03:01 AM
โFeb-05-2021 03:33 PM
โDec-25-2020 02:16 PM
โDec-25-2020 01:48 PM
โDec-25-2020 10:35 AM
โDec-24-2020 12:55 PM
deltabravo wrote:Problem is LEDs are very sensitive to voltage changes. It's not like a regular bulb that can get 12v or 16v and not explode.wopachop wrote:
Also note this style of LED does not like getting a voltage over 12.5v. Let alone the normal 13v float charge. Does your converter do a weekly 14v charge? If you notice it happen i would turn off your LED dealio.
You haven't seen the sepcs of the LEDs he bought, so your post about getting hot with voltages too high, etc. and "Amazon LEDs being bad" and the like is unfounded.
โDec-24-2020 12:16 PM
โDec-24-2020 06:40 AM
โDec-18-2020 12:23 PM
โDec-17-2020 04:16 PM
DrewE wrote:
Most LED dimmers are PWM chopper circuits, I believe; they rapidly switch the LEDs on and off with a varying duty cycle.
โDec-17-2020 04:13 PM
โDec-17-2020 04:01 PM
โDec-16-2020 06:27 PM
โDec-16-2020 05:16 PM
wa8yxm wrote:
Ever measure the output of a "Wall wart" almost always hotter than labeled.
