Fresh water tank
lcperdue
I'm new to RVing, and I don't understand my fresh water tank. I assumed that it would be a sealed tank. If I fill it beyond 3/4 full I will lose A LOT of water when the coach is moved. I don't know where the extra water goes at fillup, but it comes from a hose protroding from the sealed bottom of the coach, which is a 1999 Beaver Monterey Redondo. The hose is not the low point drain.
15 REPLIES 15
RonWSl
I had the same problem with my 07 KZ Montego Bay 5th wheel (apparently that is a common problem for that unit) and researched the issue a great deal. I was lossing a 1/4 plus of my tank just by driving a few hundred miles. Wife was not happy to run out of water in the middle of a shower.
What I ended up doing was placing a shut off valve in the overflow tube.THEN, so as to not try and fill the tank or use it with the valve shut, I put labels on both the outside fill port AND on the pump switch inside the RV. The only other option I came across in my research, was to do as already suggested, extend the overflow hose lenght and mount it higher.
Racerchaser27
WILDEBILL308 wrote:
valhalla360 wrote:
The tanks have a vent built in for a reason. If you want to move it up higher, that shouldn't hurt but don't try to seal up the tank or you will eventually break something. If you are lucky it will be something easily reached and cheap.
I have come to the conclusion there is nothing easily reached and cheap on a RV.
Bill
The screen in the vent line beside my gravity fill on my TT popped out, I came up with the cheapest solution to losing water while driving. I took a simple bolt, smaller than the hole and put a couple wraps of black electrical tape on it, but small enough to jam in the hole as a plug. Can't get any cheaper than that.
I would sometimes lose 5 or more gallons on our way to the racetrack due to cornering. Now I don't lose a drop. Put it in after filling and take it out once there.
mnoeltne
Bill
I think this is corollary # 1033 to Murphy's Law.
Mark & Joyce Noeltner
2005 Fleetwood Fiesta 26Y
2001 Jeep Cherokee Sport
WILDEBILL308
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
Bobbo
Oooh, a vent for the vent.
Bobbo and Lin
Dusty_R
I'd put a Tee in the line right where it comes out of the tank, then out of the top of the Tee run a line up a few inches to prevent water from spilling out. this will stop water from being siphoned out of the tank.
Dusty
valhalla360
Nomad III
Nomad III
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
jmcgsd
I'd be concerned with that valve when climbing or descending. Seems to me that you could build up excessive pressure or a dangerous vacuum in the FW tank - at least more than that system is designed to handle.
I'd rather lose a bit of H2O.
'09 Pacific Coachworks Tango 276RBS
95 Lance 880 Truck Camper
'91 F350 Dually 2WD CC 7.5L (76K Original miles!)
AirLift Bags, Reese Titan hitch, Rancho 9000X
Gjac
dbbls wrote:
eHoefler wrote:
Install a valve in the overflow line. When full after filling, close the valve and arrive with a full load of water.
Just don't forget to open it when you start using the water pump.
Or don't forget to open it when you fill your tank, I saw the results of this when I guy I was traveling with to Alaska forgot to open the valve and the tank expanded like a balloon an broke the support structure for the tank. Myself and another guy spent all afternoon doing a fiber glass and metal repair to support his tank again. How I solved this problem after losing many tanks of water was to reroute the overflow line higher than the exit hole. I made a clip to hold the line up to the bottom of the floor about 4 ins higher than where it comes out of the top of the FW tank.
BarneyS
Moved to Tech Issues forum from DIY.
Not towing now.
dbbls
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
eHoefler
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
tenbear
Mine splashes out the fill opening too. The tank can't be sealed since air has to come in to replace the water being used.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
old_guy
going around corners will let the water shoot out the fill opening. have seen water shoot out of mine many times.
