โAug-24-2014 09:06 PM
โSep-09-2014 08:48 AM
โSep-08-2014 03:19 PM
WILDEBILL308 wrote:valhalla360 wrote:
The tanks have a vent built in for a reason. If you want to move it up higher, that shouldn't hurt but don't try to seal up the tank or you will eventually break something. If you are lucky it will be something easily reached and cheap.
I have come to the conclusion there is nothing easily reached and cheap on a RV.
Bill
โAug-27-2014 10:39 AM
Bill
โAug-25-2014 08:15 PM
โAug-25-2014 06:12 PM
โAug-25-2014 03:15 PM
โAug-25-2014 01:56 PM
โAug-25-2014 08:16 AM
โAug-25-2014 08:11 AM
dbbls wrote:Or don't forget to open it when you fill your tank, I saw the results of this when I guy I was traveling with to Alaska forgot to open the valve and the tank expanded like a balloon an broke the support structure for the tank. Myself and another guy spent all afternoon doing a fiber glass and metal repair to support his tank again. How I solved this problem after losing many tanks of water was to reroute the overflow line higher than the exit hole. I made a clip to hold the line up to the bottom of the floor about 4 ins higher than where it comes out of the top of the FW tank.eHoefler wrote:Just don't forget to open it when you start using the water pump.
Install a valve in the overflow line. When full after filling, close the valve and arrive with a full load of water.
โAug-25-2014 07:10 AM
โAug-25-2014 06:11 AM
โAug-25-2014 04:56 AM
โAug-25-2014 04:24 AM
โAug-24-2014 09:55 PM
