My furnace flame started popping off and on. Then the next day refused to light. Or rather it would light briefly then go out. Did this 3-5 times then stopped trying. The blower ran a bit longer then stopped.
The problem? Propane regulator on the tanks went bad. If you looked closely at the range flames, they were a little lower and more yellow than normal. The Frig and hot water heater kept working too. It was just the furnace that wasn't getting enough propane.
New regulator at the tanks fixed it.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
