Generator and an EMS
rvnutts
Hi all, we are new to dry camping. We have a Progressive Industries EMS. When i plugged the EMS into the generator, it would not power the rig. However, it did power the rig without the EMS. Note: the EMS threw up a PE code, open ground. I guess my question is, no EMS with a generator? Thanks!
Brian and Lynn
2017 Ram 2500 SLT 6.7L
2013 Heartland Big Country 3250ts
13 REPLIES 13
3_tons
Agreed, the EMS is sensing that the Generators ground is not bonded with neutral at the output or shore power entranceโ€ฆA self-Bonding plug should cure thisโ€ฆ
Bobbo
pianotuna wrote:
EMS is not really needed with a generator.
What generator do you have?
Unless the generator screws up and throws high or low voltage. Anything made by man can fail.
Bobbo and Lin
Sagebrush
If its an inverter generator you probably just need a plug with the jumper. My Honda inverter generators won't work with EMS as is too.
EMS is still useful with a generator, it gives you high and low voltage protection. I had an Onan 5500 set off my Progressive EMS system, it was putting out 142 volts. I've also had that happen with other standard generators. I like keeping those $10 plug in voltage meters plugged in all the time, usually I can see the problem before its really a bad problem.
bikendan
x2!
Dan- Firefighter, Retired:C, Shawn- Musician/Entrepreneur:W, Zoe- Faithful Golden Retriever(RIP:(), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
bobsallyh
rvnutts, go here. I too just added a Predator genny to our fiver, fired it up with EMS, Progressive, turned on. No power. This fixed the situation quickly.
https://www.rvtravel.com/rv-electricity-generator-neutral-bonding-basics/
rvnutts
Hey thanks everyone! Ill let dh see your responses! Hopefully we will figure it out!??
Brian and Lynn
MrWizard
Moderator
Moderator
I forget who makes the Onan portable GENERATOR (Cummins who owns Onan, has it Mfg for them, not Mfg in the Onan factory)
But the EMS should not be needed
The EMS protects against shore power outlets that are wired wrong, an open ground or neutral, utility power transient spike voltages, brown out low voltage that could damage appliances like the air conditioner or 120v fridge, etc..
Your Onan will shut down if overloaded, (does not create low voltage unless overloaded) and does not create transient spikes, won't have an open neutral or ground unless something comes loose due to vibration or damage
I can explain it to you.
1997 F53 Bounder 36s
wa8yxm
The EMS wants to see neutral and ground bonded on the SERVICE side (park breaker panel) and most portable generators Ground is N/C since it's not needed and serves no purpose A bonding plug is easy to make
Or if you have a good Inverter Generator. Skip the Surge Guard when using the Generator. Same applies to ONAN RV generators. they self monitor and shut down if out of specs. At least mine did.
pianotuna
Nomad III
Nomad III
Regards, Don
IAMICHABOD
enblethen wrote:
Sounds like the neutral and ground are not bonded. There needs to be a direct connection between neutral and ground.
Get a male 15/20 cord body. Install a jumper between the ground and neutral pins. Plug it into a receptacle.
A plug Like this one will solve your problem and make your EMS work properly.
Many inverter generators are not grounded,my Generac is, so no need for this plug.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rvnutts
Its a portable onan 3700. Maybe the EMS is not needed on the portable generator??? We always use it when plugging into shore power.
Brian and Lynn
jdc1
Is it an inverter generator?
