โJul-25-2014 07:52 AM
โJul-25-2014 02:20 PM
smkettner wrote:Now that is super slick!!! I love that idea!! Thanks.
I would not pump but rather just connect a passive line to roughly equalize the tank levels.
Something like a FLO TAP Saddle on the drain pipes:
http://www.plumbingsupply.com/hot-wet-taps-for-pvc-pipe.html
โJul-25-2014 02:14 PM
mbopp wrote:We don't use the galley sink for anything but liquids anyway. The equalization method you suggested is a good idea but I'm thinking about having to loosen the garden hose to get the cap off every time we dump unless I can leave enough slack in the hose. (The hose would have to be around 16 feet as the tanks are on opposite ends of the trailer.) The only issue would be when dumping I would have whatever water that is in the hose and caps on the ground when removing the cap to dump. But on the bright side I would only have to dump from the rear valves. See any other issues with this?
I've been using a cheap HF 12V pump to off load my gray water to a 30-gallon drum in the truck bed. Never had an issue with clogging but we're careful about letting big chunks of food go down the drain.
I found a NIB macerator pump on Craigslist. It has more volume and pressure than the cheap pump.
The cheap way to equalize the gray tanks would be to get 2 caps w/ garden hose nipples and make a short piece of hose w/ female connectors on each end.
โJul-25-2014 01:56 PM
โJul-25-2014 01:34 PM
โJul-25-2014 09:02 AM
the bear II wrote:This is the idea that I keep going back to. Do you think the pump would have enough "umph" to overcome the back pressure of the pump-to-tank getting 25 gallons or so in it?
To pump from one tank to the other if you have two separate dump valves for the grey tanks, you could get by using a 12v water pump but a macerator pump might be better. The macerator pump would break up any small solids (hair, sand, gunk...etc) that might come from the shower.
You can get caps with garden hose attachment bibs, connect a garden hose between the two dump valves. Cut the hose and tie in the macerator/water pump to pump from one to the other. The macerator pump would also provide the ability to pump out all of your tanks to something other than a dump station (like a sewer clean out connection) if needed.
โJul-25-2014 08:44 AM
โJul-25-2014 08:20 AM
โJul-25-2014 08:19 AM
โJul-25-2014 08:08 AM
no-logic wrote:
We have a 2012 Palomino TT with a gray water capacity of 74 gallons which is great. The problem is it is two separate tanks - one bathroom and one galley. Our issue is that we fill the bathroom tank in 2-3 days between my wife and I taking showers, etc. The galley tank is used very little since we always do our dishes outside with plastic tubs. We have been using buckets to drain some of the bathroom gray water and then dump it into the galley sink. But what I would like to do is either plumb the tanks together somehow or use some sort of a pump system to run the bathroom gray into the galley tank. I'd like to make the process of transferring the water as easy as possible. Has anyone else tackled this issue and, if so, what did you do? Thanks.
โJul-25-2014 07:59 AM
