โNov-21-2014 03:14 PM
โNov-30-2014 06:35 PM
โNov-30-2014 03:49 PM
โNov-30-2014 02:16 PM
Dave H M wrote:
Hold on there folks. That E 10 is the answer to all ills.
if it weren't for it what the heck would we have to put the blame on? :W
โNov-27-2014 08:07 PM
Tvov wrote:dclark1946 wrote:Tvov wrote:77charger wrote:
Al my small engine stuff i just leave the fuel valve on except when transporting never had an issue with gumming or plugged jets.My honda gen gets used atleast once a month.
Most i know who have problems are the ones who drain all the fuel out of carb and let it sit.My guess would be that the carb in mine stays wet vs drying and leaving the residue.
Yes, if you use small engines at least once a month, then you don't have to do any special additives or draining. Storing an engine without running it is the issue.
Not if you store it properly meaning getting all of the gas out. I have four Honda generators that are not used very often and all of them are stored dry (really dry not just running it until it quits the first time). When I need one I put fresh gas with Stabil Marine in it and crank it 13 times or so and it is off and running.
Dick
I
Okay, I think we are talking in circles now!
โNov-26-2014 03:24 AM
Dick
โNov-25-2014 07:20 AM
Oasisbob wrote:
Your post surprised me. I have had my trusty Honda for many years and have yet to have anytrouble. I do use STA-BIL fuel stabalizer. Wonder if that made the difference. Sounds like your pilot jet is clogged or gummed.
โNov-25-2014 04:55 AM
โNov-25-2014 04:05 AM
โNov-25-2014 03:32 AM
โNov-24-2014 04:42 PM
โNov-24-2014 11:55 AM
โNov-24-2014 11:34 AM
โNov-24-2014 04:45 AM
dclark1946 wrote:ScottG wrote:
Your better off draining the fuel from the carb because running it dry will not totally empty the bowl and whats left will dry up and leave residue behind.
My Honda generator gas maintenance is as follows:
Use Stabil marine in all gas that goes in the generator
Syphon gas from tank within a month of last use
Drain carb by opening screw on carb underside
Crank generator until it will no longer try to start
Been following this process for several years and have had no more carb issues.
Dick
โNov-24-2014 03:10 AM
ol Bombero-JC wrote:mbopp wrote:
I siphon the gas out of the tank and then run it until the carb is dry. For insurance I also open the carb drain. And all my small engines get non-ethanol gas.
The ethanol free gas is great......if you can get it.
Soon - your state will be like CA....and not available.
The site for the *few* supposed ethanol free station locations selling same is incorrect for CA.
