have power from batteries but not to plugs??
mudrat025
Hello. I am camping without shore power and lights, radio, fans waterpump ets. Is running fine off of the batteries however none of the plug ins are working.if I run the generator the plugs work shouldn't the plugs work off the batteries???
14 REPLIES 14
MEXICOWANDERER
vs.
__________________________
My AC battery thinks this is funny question Jaja
2oldman
lanerd wrote:
. what is the difference between 12v and 12vdc??? hummmmm?
12v hums louder.
lanerd
M GO BLUE wrote:
lanerd wrote:
M GO BLUE wrote:
Your plugs work off electricity and not 12V...as already said the plugs have to be supplied with electricity via inverter and/or generator or being plugged in
Uhhhh.. the last time I looked, 12vdc was "electricity" too!
I said 12v not 12vdc like you wrote...make sure you have your facts clear before you jump on something
So tell me Mr. Get your facts straight.... what is the difference between 12v and 12vdc??? hummmmm?
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
M_GO_BLUE1
thanks for the laugh today guys...you are all so easy
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
3_tons
mena661 wrote:
12V is still electricity.
Yep!!
mena661
M_GO_BLUE1
MEXICOWANDERER
THIS IS A RECEPTACLE (120vac)
THIS IS A SOCKET (12-volts Battery)
Old-Biscuit
Basic RV AC & DC Electrical System Block Diagram (with converter & inverter)
lanerd
Ron & Sandie
TPMS: Pressure Pro
mudrat025
Ok I just realized my buddys tv is plugged into a inverter and that's why its working...thanks guys!
M_GO_BLUE1
ktmrfs
NOPE!!!! The only thing that will work off the batteries are items that run on 12V power. the plugs are 120V, and for that you need either shore power or an inverter.
The following are common items that require 120V and won't run on the batteries:
Air Conditioning
Microwave
ALL the normal 120V plug outlets
Some TV's require 120V
In addition, normally when not hooked to shore power the Fridge will run on propane, the WH will run on propane, but if it also has an electric mode, that requires 120V power.
Also, when running off a generator I'd suggest setting the fridge to "gas" and NOT trying to use the WH electric mode. And you may find that trying to run the AC off the generator is not possible unless you have a reasonably large (>3000W) Generator.
2011 Keystone Outback 295RE
3_tons
If your asking will the 120v plugs work off the battery alone the answer is no unless you have a 12v to 120v inverter, or start the generator. Sorry, its not clear to me what it is you're asking.
