May-13-2018 10:00 AM
May-13-2018 11:23 AM
SoundGuy wrote:Leeski Clan wrote:
I installed a GoPower IC 3000 which is an inverter, charger and transfer switch combo unit.
In testing, I first ran the TV which pulled ~1.5 A. Then I ran the Norcold 2118 refrigerator and according to the GoPower monitor, the Amp draw went from 1.5A to 48A!
Your new Norcold 2118 is a 2-way gas absorption fridge designed to automatically switch over to run on gas when shore power isn't available so why would you attempt to run it on an inverter? :h Specs, including current draw, are included in the specs I linked to.
May-13-2018 11:20 AM
time2roll wrote:
I call normal for an absorption fridge. Set the fridge to propane only while using the inverter. Or is this a compressor fridge?
Actually mine draws about 30 amps so I assume yours has more features. You want to see some real amps... put the water heater on 😉
I would recommend 600+ amp hours battery for a 3000 watt inverted.
May-13-2018 11:12 AM
I would recommend 600+ amp hours battery for a 3000 watt inverter.
May-13-2018 11:11 AM
May-13-2018 11:09 AM
May-13-2018 11:07 AM
Bud
USAF Retired
Pace Arrow
May-13-2018 11:03 AM
May-13-2018 10:54 AM
May-13-2018 10:42 AM
turbojimmy wrote:Harvard wrote:
40 Amps at 12 VDC = 480 watts OR 4 Amps at 120VAC = 480 watts....could be true...
Yeah that's about right for a 120V heating element. Mine says it's 300 watts but I never checked the actual draw on it.
May-13-2018 10:39 AM
May-13-2018 10:33 AM
May-13-2018 10:32 AM
May-13-2018 10:23 AM
May-13-2018 10:16 AM
Bud
USAF Retired
Pace Arrow
May-13-2018 10:09 AM
