โAug-25-2022 07:03 PM
โAug-30-2022 06:20 AM
Gdetrailer wrote:I don't know the history of this RV except that prior to me purchasing it a year and a half ago, it was set up permanently in this location in central Florida for 7 or 8 years. During the winter the roof is shaded for part of the day by pine trees, but it is in full sun the rest of the year.
Unfortunately, I myself have found that FRP doesn't hold all that well when used for roofing applications.
I used FRP to replace a aluminum roof that the previous owner shot thousands of air nails through as they attempted and failed a rehab of that trailer. The FRP performed well for me for about 7 yrs but after that it started cracking and tearing it's self apart in places with no rhyme or reason..
Gdetrailer wrote:One of the two soft spots where the plywood has rotted due to water wicking into the FRP's fabric spans a couple of rafters, and yet the color of the surface is uniform--there is no evidence of any rust bleeding through or any cracks despite the RFP having sagged slightly due to lack of support.
For yours, the discolorations look to be rust color to me.
The rust could have come from the substrate layer via staples or other fasteners used to fasten the substrate to the roof framing.
But to get that rust to bleed through it would mean that the cracks developed over time and allowed water to slowly seep into and though the FRP layer..
Gdetrailer wrote:Discounting these two spots, I can find no evidence the top layer of the FRP is deteriorating and therefor reaching the end of its life. But, the inherent weakness of these types of roofs, namely the constant maintenance, is encouraging me to look closely at roof systems such as Crazy Seal and RV Armor because those products seem to be integrated systems rather than a series of band-aids like that of a typical RV roof.
I have found that FRP top layer sheds moisture well, but once the top layer erodes some the moisture can be wicked into and through the FRP and into the substrate under it that it is glued to..
Once the raw fiberglass under the top layer has been exposed to UV from sunlight, it tends to breakdown, gets brittle and flake off.
โAug-29-2022 10:08 AM
โAug-28-2022 06:27 PM
โAug-28-2022 09:32 AM
โAug-27-2022 06:09 AM
โAug-26-2022 10:11 AM
HarryB1 wrote:theoldwizard1 wrote:The roof is not constructed like a boat's hull, but rather has a thin layer of fiberglass which is bonded to a fabric backing with a total thickness of about 0.030". When I was replacing the skylight I had to be very careful as I was removing the old caulk to not puncture the roofing material because it is quite flexible, and I did puncture it in one spot.
If this is truly fiberglass, then it is built like a boat, probably like the deck/roof; resin and 'glass over plywood or foam core.
My guess is that those spots are "dry spots" where the 'glass was not thoroughly wetted. It should be repaired using the same steps you would for boat repair. It dies seem odd that a fingernail can dent it as fiberglass cures very hard.
(snip)
Click For Full-Size Image.
โAug-26-2022 09:11 AM
โAug-26-2022 06:21 AM
(snip)
โAug-26-2022 06:08 AM
โAug-25-2022 11:50 PM
HarryB1 wrote:
This second picture shows an area some distance away where I discovered a brownish spot similar in color to those in the first picture, but there were no cracks. I began to scratch at it with my fingernail, and after discovering the surface felt soft, it came off with very little effort, resulting in this hole.
The rest of the surface of the roof seems to be quite solid. I can put an indent into the fiberglass with my fingernail, but nowhere does it feel soft like it did at this spot.
Is this an indication the whole roof is beginning to fail, or something else?
โAug-25-2022 09:32 PM
