Hot water heater problem
upstech76
Helping a family member work on their TT. They have little to no water flow through the hot water tank. I've checked all the obvious and pretty sure a check valve is stuck but not sure where it is located. Here is what I know.
1. Water Input (bottom) valve is open.
2. Water Output valve (top) is open.
3. Bypass is closed (when I do open this water will bypass the heater and flows out the hot side of the kitchen/bath tap.
4. Hot water flows from the blow off valve when opened.
So the problem as to be between the tank and the T for the bypass right? Would the right angle piece coming from the tank contain a check valve? Would the output valve have a check valve in it?
Thanks in advance.
Michael
2013 Forest River Puma 28'
19 REPLIES 19
RoyB
This is a pictorial of how the three values work for normal and winterized positions.
Note the values will show which direction the water flow is. Inline is OPEN - across the line is closed.
Hope this helps...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
dbbls
The two clear valves look like they are partly closed, especially the bottom one. Make sure they are both wide open. Normally the handle should be parallel with the pipe to be open.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Old-Biscuit
It's not necessary for a 3 valve WH system to have a check valve......but all your symptoms point to a jammed check valve in HOT outlet (or the shut off valve isn't opening)
The check valve would be inside that fitting right at tank on HOT out.....probably in the straight fitting vs angled fitting. No check valve in shutoff valve.
Turn off water supply...relieve tank pressure via PRV in outside compartment. Then disconnect the screw fitting on angled piece. Turn on water supply (just crack it open) and see if any flow comes out of top fittings. Bucket/towels to stem water drip/flow.
You can remove internals completely and do without the check valve.
enblethen
Look closely at the incoming cold water line. It could have a check valve. They don't look like much, just a short nipple on outside but is actually a check valve. It is use to prevent hot water from backing into the cold water line.
You could remove the drain plug and see if you get good water flow into water heater.
Qest check valve
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
powderman426
the setup you show doen't have check valves. You may need to unscrew the lines one at a time and check for blockages. its possible one of the globe type valves isn't opening all the way. I would replace them with single throw valves.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
