How do I hook a 3 pin connector to a 4 pin?
calstar
First post here! I recently purchased a small camper and the runnig lihgts(I assume thats what it is) have a 3 pin connecter, can I just plug it into the 4 pin splitter I have or do I need an adaptor?
Here it is:
thanks, Brian
17 REPLIES 17
westend
Since the camper connector has "DC" embossed on the jacket, there is no reason to believe it has any pinout relationship with a standard 4-way trailer connector. I'd suggest to check continuity with the pins on the connector and frame ground, a running light fixture, any backup lights on the camper, any taillight fixtures, and a wire leading to the battery compartment (should have one of those three colors).
If you want connectivity to the truck, I'd suggest to buy a 4-way "Y" splitter (fairly typical and easy to source) and make a custom pigtail to connect to the camper. You can buy both genders of individual pins to make the pigtail (might even get lucky and find the 3 way connector to modify).
Good luck on your wiring, that's a sweet rig.
'03 F-250 4x4 CC
wnjj
MEXICOWANDERER wrote:
Might be useful to note that tail lights and running lights in this case, are the very same connection.
That's true in pretty much every RV wiring case.
MEXICOWANDERER
Cloud_Dancer
I would convert truck and trailer wiring to conventional 4-wire. It would pay off in the long run. But, that's just me.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
mkirsch
Nomad II
Nomad II
Yup, that 3-pin is not standard for trailering. Odds are you would've blown a fuse or two had you tried to plug that into a 4-pin trailer connector.
Get your 12V jumper box, and a couple of nails to use as probe pins, and figure out which wire does what. As stated above you probably have running lights, 12V "house" power, and ground.
What you can then do is wire up a custom adapter using a 7-pin Pollack style connector, with a 4-pin for the trailer and a 3-pin for the camper. The 3-pin can be made from a 4-pin by hacksawing off the extra pin.
You will probably need to install the "Stud #1" fuse in the fuse panel under the hood of your truck, in order to get 12V power to the trailer plug.
Chris_Bryant
wnjj wrote:
Ok so your camper has no tail lights. You probably have ground, running lights and +12v for interior lights. You'll have to wire up something custom from the 7-way on the truck or just put a 7-way on the camper.
Be sure to figure out what each does before hooking them up.
x3
-- Chris Bryant
enblethen
With new information, I go along with wnjj.
You still should test to be sure.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
wnjj
calstar
Thanks for all the info guys! I wasn't too clear about my set up, I have the new to me(ntm} camper on my truck and a utility/camping gear hauler trailer that the truck tows. The trailer is connected by the typical 4 pin and all its lights work great. My initial idea was to get a splitter and/or adapter that goes to both the trailer and camper, but was not sure how to do it because I cant find a 4 to 3 pin adaptor.
All the info you've posted is great and I'll start testing what is what and when I figure it out I'll post the results, probably really basic but this is all new to me.
thanks again, Brian
camper ready to return home after purchase a few weeks ago, small but since I have a 1/2 ton truck its perfect, beats the hell out of the shell I previously used. Pic is a bit blurry and distorted, cell phone camera
gear hauler trailer, made from old utility bed and truck frame its mounted on
wa8yxm
Depends on the lights
On the 4 pin the "odd" one is ground
Then the one next to it is tail light/running lights
Right and left turn/stop are the remaining two (not sure the order
I do not I am thinking that on your trailer either they use the hitch as the ground in which caSe you going to have to adapt.. OR.. they left something off (tail lights perhaps).. In any case I think you are in for work
You will need to identify each wire as to what it feeds. And as I said. not sure if the "odd" one will be tail light or ground.
Chris_Bryant
I would bet that the plug has turn signal/brake lights and running lights, but no ground- at least that's what the colors are. (they did sometimes rely on the ball to ground.
You could try buying a four wire plug for the trailer, hook color to color, adding the white ground to the frame.
-- Chris Bryant
1492
Moderator
Moderator
Moved from Forum Technical Support
bob_nestor
I believe DougE is right on the mark. His advice corresponds with standard trailer wiring color codes shown on the Etrailer web site.
DougE
On the surface, it appears that if you plug it into a 4-way on your tow vehicle you SHOULD have Stop, Right Turn and Left Turn (if the wiring is true to standard trailer wiring). In lieu of any other wiring going to the trailer you wouldn't have running lights. Not sure if this is even legal in California. There's an outside chance that the 3rd wire (not the green or the yellow) is the running lights and the ground is through the hitch ball using the frames of the trailer and tow vehicle for a ground path. But if you're plugging into a properly wired 4-way on your tow vehicle that shrouded prong on the left will be plugging into a ground.
Currently Between RVs
