How do you measure the ambient temperature?
hedgehopper
Revised to read: How do you measure the temperature of the air around your rig?
17 REPLIES 17
Bobbo
Grit dog wrote:
Welp must’ve touched feelers with the mod. Thanks for deleting something that was well, opinion, just like all the rest of the opinions.
If I want to know how warm it is where I am at, I go outside. If I want to know how cold it is, I use my phone.
If I want to know how warm it is somewhere else, I use my phone.
I wondered why my answer went from the first answer on page 2 to the last answer on page 1.
Bobbo and Lin
free_radical
I used to have APP on my phone that was quite acurate but deleted it due to much spam ADverts
hedgehopper
Message from the OP: Thanks for all your inputs. I ordered an Unni Wireless Outdoor-Indoor Thermometer with 3 outdoor sensors that I plan to place one on each side and one at the back of our Class A. The base station shows all three sensor readings at once. Presumably the lowest is in the shade and is the most nearly correct reading.
StirCrazy
Moderator
Moderator
I look at my phone to see what the forecast and current temp is. If I don't have service, I don't really care that much to worry about it.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Cummins12V98
Our sensor is mounted to the frame behind the steps with velcro. Works great until the Sun is pointing to that side of the RV.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
rhagfo
We have a LaCross weather station with the temp sensor mounted up in the pin box next tot the umbilical cord. Stays in the shade and is accurate.
Grit_dog
Navigator
Navigator
bucky
There's an ap for that.
Puma 30RKSS
Bobbo
A thermometer in the shade.
Bobbo and Lin
bpounds
Add me to the wireless in a propane cabinet club. I know it is not accurate there, but it is close enough for government work. Shaded. Open to air from the bottom. Placed on an outside wall so that minimal effect of coach interior temp.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
wa8yxm
Well there are proper ways and normal ways
Standard method is an outside thermometer You can set it on the picnic table but make sure it's in the shade.
If you want to get "Fancy" design a "pagoda" type house to set over it. Good ventilation and fully shaded so it's not reading sunlight.
Now there are lots of proper "Shells" for outside thermometers.
Oh. you can get one of the wireless types so you can read the outside temp. from inside...
Just make sure it's out of the sun and has good ventilation around it.
Cptnvideo
We have an "Ambient Weather" brand weather station that will monitor 3 sensors. The sensors are hung under 3 corners of the RV - at least one will be in shade. It is interesting to read the 3 sensors at different times of the day as well as the high and low for the day at each sensor.
Bill & Linda, 2019 Ram Laramie 3500 dually 4x4 diesel, Hensley BD5 hitch, 2022 Grand Design Solitude 378MBS, 1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LFP batteries for 1030 ah
rk911
use a simple thermometer placed in the shade.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
agesilaus
The cheap way is to get one of those stick-on thermometers that go on the outside of a window.
We have a wireless with three remote senders. One under the propane tanks, one in the fridge freezer and one in the bedroom. About $40 from Amazon IIRC
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
