โOct-29-2014 05:28 PM
โNov-05-2014 04:30 AM
โNov-05-2014 04:07 AM
โNov-05-2014 03:42 AM
Raften wrote:
Question about the meter that rjfishing put the link for. It seems to say you would need to power it from a separate battery.
โNov-04-2014 01:57 PM
โNov-04-2014 10:00 AM
โNov-04-2014 08:22 AM
โNov-03-2014 09:04 PM
โNov-03-2014 02:19 PM
โNov-03-2014 01:10 PM
Raften wrote:
When you install a shunt in the negative battery lead, do you cut the big wire or run a smaller wore in parallel?
โNov-03-2014 09:47 AM
โNov-03-2014 06:19 AM
โNov-02-2014 11:50 PM
โNov-02-2014 05:53 PM
โNov-02-2014 03:31 PM
wa8yxm wrote:
Most standard multi-meters will meter up to 10 amps wheh put in series with the load (Easiest way is to pull the fuse and repalce with the meter and an in-line fuse holder).
However for bigger loads go to Sears. A Crafstman model 82369 will do up to 400 amps clamp on, However it does NOT indicate direction of flow when used clamp on.
