โAug-06-2013 06:32 AM
โAug-09-2013 06:19 PM
Harvey51 wrote:
Jmsokol, I'm glad to have opportunity to thank you for your most interesting article on the dangerous double wiring mistake that isn't detectable without a no contact tester. My old electrician friend and I quite enjoyed it and we will now be using our no contact testers when checking outlets.
It seems so unnecessary to hire an electrician just to hook up an outlet but the evidence is that there are quite a few people who don't know as much as they think they do about wiring.If everyone followed code it should be simple. But I've seen a lot of houses, stages, RVs, and sound systems that were wired terribly. Knowing how to read and interpret meter readings is vitally important when you're hooking into unknown power sources.
โAug-09-2013 06:02 PM
โAug-08-2013 11:42 AM
โAug-08-2013 01:13 AM
joebedford wrote:
I know how to use a DVM. Maybe I've been lucky but I've never tested an outlet before plugging in. How many people actually have problems? (yes, I know it happens sometimes).
โAug-07-2013 03:41 PM
โAug-07-2013 02:36 PM
โAug-07-2013 02:14 PM
โAug-07-2013 01:57 PM
โAug-07-2013 09:29 AM
โAug-07-2013 08:51 AM
Bud
USAF Retired
Pace Arrow
โAug-07-2013 08:36 AM
โAug-06-2013 06:30 PM
RichieC wrote:
A VOM is well worth learning to use, BUT if you don't use it all the time or don't have the desire for it you may find yourself unsure of your ability to use it.
As suggested, use a polarity tester to back up your diagnoses.
โAug-06-2013 11:04 AM
โAug-06-2013 10:30 AM
hddecker wrote:taigarazz wrote:
So I am a bit electrically challenged. Whenever I start reading about RV electric systems, I just start nodding off. Not good, and I am trying to educate myself.
But I feel a more urgent need to understand how to use a simple volt meter to check the electric at my campsite hook up, before I plug in and fry something. So far I have been lucky, but I don't want to depend on luck for the long haul.
Thanks
This is what I use. http://www.p3international.com/products/p4400.html
