Installing cut-off switch for batteries
Yosemitebobr
I have a trailer that has a cut off switch, however, it does not cut off everything. While in storage I want everything cut off without removing the battery cables. So, my idea is to insert a cut-off switch in the positive battery cable from the battery to the fuse. I have two 6 volt batteries in series. I want to leave the ground attached, and the jumper from battery one to battery two, opening only the positive line from the second battery. Can I do this without any detrimental effect to either battery? Leaving them hooked up that is.
YosemiteBobR (Bob)
2022 Venture Sonic Lite
My DW the co-pilot/navigator (the boss):)
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL
7 REPLIES 7
Yosemitebobr
beemerphile1 wrote:
Do like you are thinking but connect the breakaway prior to the switch for safety in case it is towed with the switch open.
Yes, I did think of that, but didn't mention it, thanks for doing so.
YosemiteBobR (Bob)
beemerphile1
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
DryCamper11
Yes, you can safely do this.
Be aware that some of the cheaper cut off switches expose a great deal of metal connected to the battery when installed. For that reason, the manufacturer recommends you install those switches on the negative side. That minimizes the risk that you will accidentally short out the battery with a dropped tool, or while working on the installation. If you prefer to use the positive side (I do prefer it there) make sure you are careful and try to add something to insulate or protect the switch from accidental shorting. More expensive cutoff switches are well designed and don't suffer from this problem as much, but may need additional cables installed from the battery to the switch mount location.
In the Boonies!
ken_white
I would just pull the fuse...
๐Ÿ™‚
2014 RAM C&C 3500, 4x4, Club Cab, Hauler Bed, DRW, Aisin, 3.73's, etc...
2013 DRV Tradition 360 RSS
LED Lighting
570W of ET Solar Panels
MorningStar MPPT 45
Wagan 1000W Elite Pro Inverter
Duracell EGC2 Batteries with 460 A-H Capacity
tvman44
Yes! ๐Ÿ™‚
Papa Bob
Husky 16K hitch, Tekonsha P3,
Bobbo
That will work just fine.
However, personally, I would prefer the breakaway switch to stay connected to the battery always.
Bobbo and Lin
