โSep-30-2023 10:39 AM
โOct-18-2023 04:20 AM
โOct-17-2023 03:27 PM
โOct-01-2023 02:15 PM
Grit dog wrote:
Shook the wires and it worked again is about 95% chance an intermittent dead short in the wires you shook.
โOct-01-2023 08:48 AM
โSep-30-2023 04:06 PM
โSep-30-2023 02:52 PM
โSep-30-2023 12:25 PM
The wires are grounded to the frame there, might be worth cleaning that ground up.It's an intermitten problem. Clean or replace everything.
โSep-30-2023 12:11 PM
โSep-30-2023 12:01 PM
Bud
USAF Retired
Pace Arrow
โSep-30-2023 11:56 AM
โSep-30-2023 11:43 AM
โSep-30-2023 11:22 AM
โSep-30-2023 10:52 AM
rexmitchell wrote:This is a clear indication of an intermittent connection problem. Most likely source is the battery post connection or the wires. Flooded batteries if that is what you have vent corrosive fumes so check everything. Even shrink wrapped battery wire can/do fail between the wire and connector.
Shook the wires and it came on. Did it again and lights are back on. My first thought was the connectors but that doesnโt make sense from the original problem where I had power 4 feet away at the junction. Any ideas on what to check or replace?
