Inverter question
Lspangler
Will a 300 watt inverter run a 27 inch led tv? It says 700 max
Thanks
11 REPLIES 11
JiminDenver
We run a 19 inch TV and a Tailgater satellite system off of a 150w inverter, sometimes all day and half the night. We do have a solar system and the battery is a 8-D so power is never a issue.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
RJsfishin
Ya but, there is always the question will it handle the charging voltages of sometimes well over 15 volts.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Dusty_R
Most flat screen TV's are 12 volt to begin with. They have what's often called a wall wart, that's on the end of the cord that plugs into the 120 volt wall receptacle. If you look close at that wall wart, it will tell you that it's input is 120v and if the out put is 12v. That cord can be unplugged from the TV. Now just find a new cord that one end will plug into the TV, and the other end will plug into your 12v outlet, and has the same polarity.
Dusty
Golden_HVAC
Mfar1234 wrote:
How many hrs will two (2) batteries run a 20" flat screen?
Depends on the battery size. If you have 2 each 8D batteries, at 120 pounds each, you can watch TV all night long with 220 AH per battery. A group 24 battery is about 65 AH per battery, while group 27 is more like 100, along with group 30 and 31. Going with golf cart batteries, then the pair of 6 volts add up to 220 amp hours, and should last about 6 hours of running the inverter.
I highly recommend a solar charging system. It will keep the batteries topped up while in storage, and can top off the batteries while camping, depending on the system size.
100 - 150 watt panels will fit on most roofs.
SunElec.com
Look for 12 volt "Nominal" panels *the open circuit will be around 21.2 volts*. Also buy a PWM solar controller rated for slightly more amps than the total of your panel capacity.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
2oldman
6
Mfar1234
:C
Mfar1234
40' 2002 Alpine Coach, 400 ISL Cummings/3000 6sd Allison
2006 Dodge Ram 4x4
Brodie - Lab Mix and Baylee - Border Collie
BFL13
It's all about picture brightness how many watts the TV draws. On a 32inch LG LED it is about 70w Vivid, 50w Standard, and 35w Cinema.
A 32inch Samsung LCD is 120w Dynamic, 80w Standard, and 70w Movie, so you see how LED reduces the power requirement of an LCD TV.
A 300w inverter can run those easily plus the DVD and external powered speakers if any.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Artum_Snowbird
Your 27 will run between 60 and 100 watts only. We had a 400 watt and it ran it fine without the fan running in the inverter. It's a bit important to run silently, without the fan, as it is a long term load and a fan running only increases the load on the battery.
My Sony had a "low Power" mode that decreased the brightness of the screen and only used 56 watts for a 26 inch TV.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
enblethen
What is the max draw of the TV? It should be listed on the back.
The 700 watt is for surge type load and not for steady load.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
2oldman
Assuming the 700 means the inverter max, yes.
Golden_HVAC
Yes it will work fine.
What I did in my RV is run #10 wire to and from the battery to the inverter location near the TV set. There I plug it into a cigarette lighter receptacle. I run a 19" regular TV on a 150 watt inverter, and now a 22" tv that is flatscreeen, and can use up to about 70 watts according to my E-meter.
Fred.
Escapees.com
