โJul-12-2016 06:46 PM
โJul-23-2016 12:25 PM
โJul-23-2016 12:11 PM
โJul-23-2016 08:54 AM
โJul-23-2016 07:42 AM
donniew_1 wrote:
So do I need to replace just the load center/power converter or do I need to replace the 110 breakers, bus bar and 12 v fuse panel? All appliances seem to be in working order except the hot water heater because the before mentioned breaker is shared with the converter. Also, only two of the outlets are working; the kitchen and bath, is that because they are gfi outlets?
โJul-23-2016 01:33 AM
donniew_1 wrote:
So do I need to replace just the load center/power converter or do I need to replace the 110 breakers, bus bar and 12 v fuse panel as well? All appliances seem to be in working order except the hot water heater because the before mentioned breaker is shared with the converter. Also, only two of the outlets are working; the kitchen and bath, is that because they are gfi outlets?
โJul-23-2016 01:32 AM
โJul-13-2016 08:38 AM
smkettner wrote:
Yup. Smoke is out.
โJul-13-2016 05:38 AM
โJul-13-2016 04:28 AM
โJul-12-2016 10:37 PM
โJul-12-2016 07:41 PM
