โNov-09-2019 07:29 PM
โNov-11-2019 05:23 AM
โNov-10-2019 05:22 PM
BFL13 wrote:If the panel shorts the other two panels feed current through. If the panel fuse rating is 15 amps and you push 20 amps through the short (10 amps x2 panels) they you might get some heat.
Need a scenario. Say a tree branch falls on one of your RV roof panels and smashes it all to heck. Perhaps somehow a cell gets shorted.
Cells are all in series with each other, so hard to figure how a short can occur with pos and neg touching. But even if a cell is shorted, what will happen? Shorting the whole panel is harmless. That is how you measure Isc and Voc.
โNov-10-2019 04:30 PM
โNov-10-2019 04:20 PM
Ed_Gee wrote:Not on an RV. Tesla did recently battle Walmart due to some Solar City installations that caught fire. Lawsuit was resolved and withdrawn.
Has anyone heard of a solar panel short circuiting in its internal power connections? I have not.... just seems like a lit of work for nothing.
โNov-10-2019 02:54 PM
โNov-10-2019 02:12 PM
Vintage465 wrote:
I'm fusing my solar panels individually in the combiner box before they are combined . . .
โNov-10-2019 09:12 AM
Vintage465 wrote:
I'm fusing my solar panels individually in the combiner box before they are combined. Initially, I purchased the 15a MC-4 fuse holder and the connectors. This came out to about 6-1/2" long. Too long for my combiner box with all the other hardware in there. So, can I use any automotive inline type fuse and fuse holder so long as the the fuse size is right and the wire size(10ga) is the same? The reason I ask is the conductor/fuse is real small on an automotive 15a and I always concern my self with not carrying as much juice cause of the small fuse link compared to the 10ga wire? Meaning, is there a "special" solar fuse that carries more juice?
Thanks,
โNov-10-2019 09:07 AM
โNov-10-2019 08:59 AM
Vintage465 wrote:Good plan and no effect on charging.
Some people recommend fusing them. Some don't. Renogy recommends(or shall I say I saw in of their solar "101" info write-ups) fusing each panel. Samlex doesn't mention fusing at the panels. I don't have any issue from a technical perspective about fusing, whether or not it should be. Only from a "does it still charge as well" perspective.
โNov-10-2019 08:53 AM
wa8yxm wrote:Fuse resistance and even wiring to the combiner is normally a non issue for for parallel 12V panels. Normally rated 18-20V for 14.8V battery charging. Doubtful that even a MPPT controller with parallel panels would have any practical loss due to fuses.
The only other thing would be the "inline resistance) of the fuse (The resistance pin to pin not blown) likely too low for your meter to measure but I'm not sure how the "Solar rated" fuses compare to standard automotive/house fuses in this aspect.
โNov-10-2019 08:47 AM
Ed_Gee wrote:
Not sure I understand why one would fuse a solar panel. What rating fuse would you use? ...the solar panel is simply incapable of sourcing higher current than its maximum output.....a fuse could never blow. The other end is not a current source assuming it is a charge controller, so nothing that could provide current to blow a fuse there, either..... am I missing something?
โNov-10-2019 08:41 AM
ktmrfs wrote:Correct answer and the reason for fusing 3 or more parallel panels.Ed_Gee wrote:
single panel I agree. Multiple panels another story. Let's assume you have 6 panels in parallel. One panel develops an internal short positive to negative, each panel can supply 15A, Now all the sudden you have 5 panels suppling up to a total of 60A through the wiring on the shorted panel. not a good idea. The fuse serves as a isolation device.
Fusing requirements for solar panels are more focused on house grid tie applications where you could have a dozen or more panels in parallel.
โNov-10-2019 07:59 AM
