LCI slide control
wanderingaimles
I had a new occurrence last night. My bed slide suddenly came in. The slide is a Lippert with this control.
It will go back out after a couple of minutes. After getting up to check it, I did notice a clicking sound coming from the wall control, apparently some relays internally setting/resetting. It has gone back in by itself a couple of times since.
Will apparently have a new project when I get home.
RV is a 2010 Winnebago vista, Worm gear slide.
Anyone experienced this before?
2 REPLIES 2
wanderingaimles
Thanks Doug, I had basically done the same thing. Took it out this morning to look for a part #. Found the reset button on the slide stop set and pressed it. A half hour later put it back and it has not "misfired" again since.
It had been showing the single red flash for stop not set.
dougrainer
Remove the 2 screws that hold the wall switch. Extend the room and then unplug the harness from the wall switch. LEAVE for as many days as you can with the unit plugged in. IF the room still retracts you need a new Control module(not the wall switch). This should be the module and system. Doug
https://lci-support-doc.s3.amazonaws.com/manuals/slideouts/powergearslideouts/3010002088_m_sq_instal...
