โMay-16-2015 09:29 PM
โMay-17-2015 09:13 AM
โMay-17-2015 09:08 AM
MEXICOWANDERER wrote:
I use the $2.95 (8) amp dimmer as found on BuyInCoins.com
A 470uf 25-volt electrolytic capacitor inline BEFORE the dimmer helps.
โMay-17-2015 09:06 AM
GordonThree wrote:ledcomp wrote:
I wanted to stabilize my LED lighting circuit voltage using a buck/boost converter. When the LED's are dimmed you can see alot of fluctuation from battery voltage change like when the water pump cycles. My concern is with the PWM LED dimmer being driven by the back/boost converter. I'm trying to not let the magic blue smoke out of my PWM dimmers.
If this will work, does anyone know of a 5 amp+ buck/boost that will work with a common ground?
Thanks
Dave
Can you give more details about your existing LED setup and what driver you're using?
Any kind of simple switch mode LED driver isn't going to like you pwm'ing the load downstream of the output.
Typically the smps will have a pwm input or enable input which accepts a pwm signal for dimming.
Alternately with a smps operating in the 10s to 100s of kHz, you can just pwm the driver's power input with a low freq pwm signal (100hz for example). Make sure the driver's soft-start feature is disabled or absent.
โMay-17-2015 08:48 AM
โMay-17-2015 06:51 AM
Thanks
Dave
โMay-17-2015 03:20 AM
โMay-16-2015 10:55 PM
