LiFePo4 winter storage
steveh27
I have 2 100 AH LiFePo4 batteries in my Class B Xplorer which I will not use from the first week of December until April. If I disconnect the black ground can I just leave them in the unit? The batteries are in a case under the van.
6 REPLIES 6
Lwiddis
"On my DP the 100W solar panel keeps all six batteries topped off during the cold winter months,.."
Keeping Lithium batteries "topped off" when not in use isn't recommended by my battery manufacturer. I suggest you don't apply wet cell rules to Lithium.
3_tons
A) discharge battery to say about 60-50% SOC
B) disconnect battery cable, or install simple disconnect switch at battery terminal
C) Enjoy your worry-free winter hibernation!
3 tons
otrfun
It it were me, I'd completely disconnect each battery just to be safe. If any voltage imbalance occurs between the two batteries during storage it'll prevent any residual current flow while they're stored. Current flow of any kind in very cold weather is a no-no for lifepo4's. Also, lifepo4's don't like being floated or stored at a high SOC. Ideally, you'll leave them at 50-60% SOC for the winter.
schlep1967
I would go to the manufacturer for direction.
Winter battery storage
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
pianotuna
Nomad III
Nomad III
sch911 wrote:
On my DP the 100W solar panel keeps all six batteries topped off during the cold winter months, and I'm close to you in Troy MI. Could be good peace of mind for those LiFePo4 batteries.
Among the other quirks of Li, they DO NOT want to be float charged.
Disconnect the positive cable, wrap it in red electricians tape.
Store at 50% state of charge.
Regards, Don
sch911
OEM Auto Engineer- Embedded Software Team
