Apr-10-2019 04:14 AM
Apr-10-2019 08:09 AM
Kamphiker wrote:Chris Bryant wrote:
If I am understanding you, you don’t have a shirt, you have an open ground.
I am not 100% Positive its just a "OPEN" ground due to measuring voltage on the negative side.
Apr-10-2019 08:05 AM
Apr-10-2019 07:16 AM
Apr-10-2019 06:38 AM
Apr-10-2019 06:14 AM
Apr-10-2019 05:39 AM
YC 1 wrote:
You have an OPEN ground circuit.
Is it possible there was a screw through some metal mounting that you took out that was used as a ground? No, None attached
Perhaps the motor mounting was being used as the ground. No, the Previous motor was mounted to metal rail bit it was not grounded there. The Negative wire from the coach wiring loom was connected to the fan Motor Negative side and there was no connection the the frame holding it.
It is hard to suggest where to ground without a picture but yes, making a new ground point is ok although not ideal.
Apr-10-2019 05:04 AM
Apr-10-2019 04:39 AM
Apr-10-2019 04:25 AM
