Lost 12V Ground 1 circuit Interior Lights, Ideas on finding
Kamphiker
While Changing out Vent fan Motor in Lavatory I lost power to the circuit. This also includes 5 other Overhead Lights on same circuit.
Fuse is not blown (I have a PD4645 Converter/ charger).
In running test with my Multimeter, IF I attach a temporary ground (Length of wire/alligator clips) to the Negative side of the wire intended for the vent fan to the PD4645 case (Only because this is the only close ground source I can find, I show proper voltage (12.6 Plus depending on PD4645 charge Mode).
Second Test I ran was measure voltage through the ground side of bad circuit I get 12 Volts measured on the ground side...... Isn't this an Indication of a shorted ground ?
When I attach the Temporary ground the 5 lights work as they should (I don't know about the New Vent Fan Motor as I have not tried to put back in operation).
For the life of Me I can't find the location of fault in either the Lights (I have pulled them out of the ceiling and the appear to have no shorted wires etc) OR the wiring I can access behind the fixtures.
I Have a PDF of my RV electrical schematics from Winnebago for my Motor home (WF324V) and I'm having problems finding the connectors on the wiring harness as they don't seem to be in indicated locations.
One question is do I simply need to re-establish a good ground on this 1 circuit without finding the Break ?
is there a easier way of finding the proper ground wire other than probing all the Ground wires (I know they are the WHITE colored wires) ?
Accessing the wiring within the ceiling not possible as is the wires for the circuit that I believe run from the ceiling down the interior wall. The bundle of wires appear to run under the bed which I have to remove to access. the wire bundle at this point appears to be 20 or more individual wires.
Open to words of wisdom
Getting ready for vacation next week and this is kicking my butt.
Thanks in advance
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
23 REPLIES 23
wnjj
Kamphiker wrote:
Chris Bryant wrote:
If I am understanding you, you donโ€™t have a shirt, you have an open ground.
I am not 100% Positive its just a "OPEN" ground due to measuring voltage on the negative side.
As Chris said, you are measuring the 12V through the filament of a light bulb or some other load that is trying to turn on but has no ground. Since there is no current flowing the voltage on both pins of the bulb is the same. Light bulbs are just tiny pieces of wire.
pianotuna
Nomad II
Nomad II
Try putting the old fan back in. If that works--then remove and install the new fan?
Regards, Don
Chris_Bryant
You are measuring voltage on the ground because the ground is picking up voltage from a light thatโ€™s on. Hook one side of a light to a battery and you will assure 12 volts on the open lead. The ground is hot because it isnโ€™t hooked to ground.
As others he sai, try installing the vent fan and go from there, which would be going back through the circuit, finding the last item that works.
-- Chris Bryant
troubledwaters
Not being able to see what exactly your dealing with wire wise, its pretty hard to diagnose over the internet. My recommendation would be to finish the fan installation completely then see if things are back to normal. With the installation half complete and things not connected that used to be connected its hard to know what is going on.
steved28
It seems removing the OEM fan was the point you lost your ground. So that would be where I would find the "new" ground. As YC 1 suggested, most likely that entire circuit receives its ground from the fan mount. If you ground the negative to the fan, do your lights work? I assume they all share the same ground?
2019 Winnebago Sunstar LX 35F
2000 Jeep Wrangler TJ Sahara
Kamphiker
YC 1 wrote:
You have an OPEN ground circuit.
Is it possible there was a screw through some metal mounting that you took out that was used as a ground? No, None attached
Perhaps the motor mounting was being used as the ground. No, the Previous motor was mounted to metal rail bit it was not grounded there. The Negative wire from the coach wiring loom was connected to the fan Motor Negative side and there was no connection the the frame holding it.
It is hard to suggest where to ground without a picture but yes, making a new ground point is ok although not ideal.
Figuring out how to run the new ground wire to connect past the broken ground point is where I'm stumbling.
YC_1
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
Kamphiker
Chris_Bryant
If I am understanding you, you donโ€™t have a short, you have an open ground.t
Edited to correct bloody iPad autocorrect mistakes
-- Chris Bryant
