โMar-20-2014 12:49 PM
โMar-25-2014 09:14 AM
โMar-23-2014 02:07 PM
โMar-23-2014 11:36 AM
โMar-23-2014 09:40 AM
RJsfishin wrote:
The question was to lube or not. Over tightening is another topic.
Come on you ole timers,...........do you really use a "tork" wrench on lug nuts ?? Head bolts, and valve bodies yes, but when the day comes where I loose the "feel" of tightening a lug nut (w/ or w/o lube) short of stretching it, just put me 6'under !
โMar-22-2014 11:47 AM
โMar-22-2014 06:04 AM
โMar-22-2014 01:31 AM
โMar-21-2014 11:15 PM
RJsfishin wrote:Yup. What RJ said. I always use it on the taper, as well. Reduces galling. And as others have said, do not let some idiot "sock'em down good" with all the power his impact can give.
Yeah, like an owners manual knows everything !!
I have never heard of even one who had nuts come loose from never seize.
โMar-21-2014 09:43 AM
bucky wrote:Grow up.
I always use Deese Nuts.
โMar-21-2014 06:45 AM
beemerphile1 wrote:
Maybe not but I have seen ruined lugs that were stretched by over torquing. When a bolt is tightened it actually slightly stretches the bolt which creates the tension that keeps it tight.
If a bolt is lubed it is easy to over tighten. Once over tightened the bolt (lug) will fail due to being stretched to the point the elasticity of the metal is destroyed. Yes, I've seen it happen.
โMar-21-2014 06:07 AM
โMar-21-2014 05:23 AM
โMar-21-2014 04:43 AM
โMar-21-2014 03:28 AM
